Turbo Carbs
6 replies to this topic
#1 minikidx14
minikidx14
  • 1,387 posts
  • Name: Ross
Posted 08 December 2010 - 02:56 PM
Had a quick search but couldnt find much.
If i was running a 'blow through' turbo is the only carb i can use the sealed hif44? can i seal a hs4? are weber 45's sealed?
#2 Wil_h
Wil_h
  • 3,244 posts
Posted 08 December 2010 - 03:01 PM
The simple answere is no, you are not limited to the HIF44. However, the HIF44 is by far the easiest to use and will not limit power output.
#3 minikidx14
minikidx14
  • 1,387 posts
  • Name: Ross
Posted 08 December 2010 - 03:07 PM
#4 1380sprint
1380sprint
  • 167 posts
Posted 18 December 2010 - 05:06 PM
Where would one find a sealed weber carb then?
if i remeber didnt the lotus esprit use a sealed Dellorto?
#5 george91
george91
  • 883 posts
Posted 18 December 2010 - 10:54 PM
Yep it was a 40, as used on the janspeed turbo engine. Not sure if there still available and i expect there pretty rare.
Edited by george91, 18 December 2010 - 10:55 PM.
#6 Austinminimark
Austinminimark
  • 260 posts
  • Local Club: redditch
Posted 18 January 2011 - 04:48 PM
does that mean you can use a weber carb on a metro turbo or is that a silly question?
#7 Austinminimark
Austinminimark
  • 260 posts
Posted 20 January 2011 - 08:10 PM
doesnt matter silly question.nube.
