Leads Getting Wet
14 replies to this topic
#1 hainzie
hainzie
  • 40 posts
Posted 13 December 2010 - 07:45 PM
~~~~~Please delete this text before posting the topic~~~~~~
Please give your topic a title that quickly describes your problem. Just putting 'Help my Mini doesn't work' is useless to anyone trying to help.
Model: austin mini
Year:1988
when the leads get wet the car runs like poo and wants to die, and it doesnt then want to start has anyone else had this problem? and is there a way of keeping them dry the leads? thanks
Any non-standard parts that might be involved with the problem?
Edited by hainzie, 13 December 2010 - 07:46 PM.
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 13 December 2010 - 07:47 PM
a rubber glove over the dizzy will solve your problems
4 fingers are the leads to the spark plugs and the thumb for the HT lead
#3 L400RAS
L400RAS
  • 2,479 posts
  • Local Club: Lincolnshire Mini Owners Club
Posted 13 December 2010 - 07:48 PM
Proper distributor shield (clips not included)
#4 maggies_minder
maggies_minder
    TMFs New official Spamster
  • 4,393 posts
Posted 13 December 2010 - 07:50 PM
+1 argueably the best thing ive bought for my mini.
#5 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 13 December 2010 - 07:53 PM
Agreed a weathersheild is the best solution to the problem!! Try Here - Click for a better value version in a choice of different colours though!!
#6 danrock101
danrock101
  • 2,478 posts
I've used the rubber glove method and I've even just put a carrier bag over the dissy cap, they both worked well. But my mk3 has some plastic on the back off the grill and it hasn't even been affected by the rain one little bit.
#7 Cooperman
  • 23,285 posts
Posted 13 December 2010 - 07:54 PM
Buy a pot of non-conductive silicone grease and plaster it all over and around the distributor cap, leads nand coil. Then spray the whole lot with Ignition sealer. I can go through 12" deep fords without it misfiring and I don't have any sort of rubber glove. The only problem with a rubber glove is if it gets any condensation inside it, it is difficult to dry it out and it can in itself cause a misfire.
#8 hainzie
hainzie
  • 40 posts
Posted 13 December 2010 - 08:07 PM
i cant drive thar in this weather as cuts out,drives slow as no power, thanks for replys
#9 hainzie
hainzie
  • 40 posts
where can i buy this from? :)
#10 Cooperman
  • 23,285 posts
Posted 13 December 2010 - 08:21 PM
I use light aircraft flying control cable grease, but as I'm involved in flying it's easy for me to get. Go 'on-line' and do a search. Alternatively, you can use Vaseline and I've used this to waterproof rally Minis with good success. Just plaster it on and seal with Ignition Sealer. It really does work.
#11 hainzie
hainzie
  • 40 posts
Posted 13 December 2010 - 08:24 PM
thank you very much :)
#12 Barman
Barman
  • 1,068 posts
Posted 13 December 2010 - 08:32 PM
My first car was an 1973 Austin 1300... I would never dream of going out and trying to start it without a tin of Damp Start...
It didn't matter how often I changed the polugs, leads, distributor cap, etc. the only thing that really worked for it - especially on cold/damp mornings was a good old spray of Damp Start! :)
#13 hainzie
hainzie
  • 40 posts
Posted 16 December 2010 - 08:34 PM
dried it all out tried ignition sealer worked for a day until i got behind a lorry in the wet then it stared missing then died in the road up a hill i was not happy lol because the other caRS stared beaping at me so i think tommorow i will try the vasaline trick.
#14 Sir Cheat
Sir Cheat
  • 1,171 posts
Posted 16 December 2010 - 08:38 PM
Just buy a weathersheild there not expensive.. Job done
#15 Cooperman
  • 23,285 posts
Posted 17 December 2010 - 12:38 AM
Just to note, 'Damp Start' is not the same as 'Ignition Sealer'. I use silicone grease and ignition sealer and the dizzy sits behind the 13-row oil cooler. I do rallies in the streaming wet, with huge puddles, deep fords and mud, but I never have any ignition issues. Vaseline is as good as silicone grease, but you must finally seal with ignition sealer.
