155/70/r12?
Posted 14 December 2010 - 10:52 AM
Posted 14 December 2010 - 11:32 AM
Posted 14 December 2010 - 01:11 PM
10~15 what ? % or mph ??
Sorry, yes mph. It does rest at 0mph so it's not a simple case of moving the needle down.
Posted 14 December 2010 - 01:32 PM
It is a little high, however most cars read high by about 10%
Edited by mra-minis.co.uk, 14 December 2010 - 01:32 PM.
Posted 14 December 2010 - 04:07 PM
The chap i bought the car off told me the correct gear change for the speedo cable hadn't been installed during the engine change. But I'm just enquiring whether the tyre size can have such a significant difference and if I should convert them back to 145/70/R12??
Posted 14 December 2010 - 04:23 PM
The width in mm's the next number (70) is the percentage of the width deep, ie 70% of 145 is..... times by 2 and add it to the wheel diameter.
use 25.4mm per 1"
The error will be the percentage difference in diameter.
Edited by mra-minis.co.uk, 14 December 2010 - 04:23 PM.
Posted 14 December 2010 - 04:36 PM
and 155/70/R12 has a height of = 521.8mm
Therefore there's a difference of = 14mm
I've known mini's to be fitted with either 145 or 165 tyres but never 155. In conclusion, is this something i need to address or can just be ignored?
Thanks mra!
Posted 14 December 2010 - 04:54 PM
155 70 12" used to be a common mod
Posted 14 December 2010 - 05:07 PM
Posted 14 December 2010 - 05:12 PM
you might need a small spacer on the rear for the tyre to clear the shocks
Posted 14 December 2010 - 05:37 PM
Posted 14 December 2010 - 06:42 PM
Oh you mean which engine and what spec etc ...
To be a little picky, the engine won't have an effect on the speedo, only the gearbox will do that....
It als obegs the question how do you know that your speedo is giving the wrong reading ?
Posted 14 December 2010 - 06:45 PM
Posted 14 December 2010 - 07:47 PM
Der an engine
I believe the brittish open classics rolled out the factory with 1275 cooper engines, however it was changed to a metro 1275 with HIF44.
The guy who I bought it from told me about the change and the fact that the speedo gearing wasn't quite right. And also when i've got my sat nav plugged in, it is roughly 10mph out.
Posted 14 December 2010 - 08:01 PM
My Sat Nav is about 10mph out in comparison to whatever car I put it in, I'm not sure if this is an example of how inaccurate all speedos are or just how inaccurate Sat Nav is???
