Auto Mini Dies In Drive
4 replies to this topic
#1 Tommole
Tommole
  • 21 posts
  • Local Club: Not as of yet
Posted 15 December 2010 - 02:36 PM
Model:City
Year:1988
HI,
I have a 998cc mini automatic which dies when i put it into drive which comes particularly dangerous at traffic lights and junctions as you can imagine. Usually what happens is when i stop the engine drops to 100-200 rpm then stops. Sometimes i can pull the choke out to stop this but it doesn't always work thought. Also i have noticed that when i can then pull off its slow on the uptake for a few seconds then picks up, however once its going it drives perfectly fine. I have been told that it 'could' be the valve heads as ive been running on unleaded fuel which might have damaged them, but i want a second opinion, and im also not very good mechanically with cars so as much info about it would be very appreciated.
cheers
Edited by Tommole, 15 December 2010 - 02:37 PM.
#2 Beej123
Beej123
  • 1,184 posts
  • Local Club: Splinters Mini Club
Posted 15 December 2010 - 02:52 PM
If your valves are for leaded petrol its only as matter of time before you start getting misfires, it may not cause this specific problem but it will become a problem eventually, you can either change the valve heads or start using a lead additive with the unleaded petrol, i would get a mechanic to look over the valves though to make sure they are not already damaged, as far as the problem of dying when stationary my guess would be a clutch problem, thats why the choke helps sometimes, brings the revs up. Like i said though, just a guess.
#3 Tommole
Tommole
  • 21 posts
Posted 15 December 2010 - 03:00 PM
ill start using the additive but not to sure if the damage has already been done too much.
Thanks for your help
#4 hainzie
hainzie
  • 40 posts
Posted 15 December 2010 - 03:04 PM
i got this problem got manual engine tho, could be your leads getting wet?
#5 Tommole
Tommole
  • 21 posts
Posted 15 December 2010 - 03:10 PM
That could be part of the problem or at least doesnt help it. in the rain the revs go very high and i cant go above 30. if this isnt part of it its certainly another one O_O|
