What Is Needed To Fit Self Leveling Mpi Lights Into An Older Mini?
11 replies to this topic
#1 jkjaxor
jkjaxor
  • 331 posts
Posted 15 December 2010 - 11:35 PM
just wondering what is needed, obviously motors but is there a controllbox or is the leveling system built into the motor,and i just supply power,, also how does it mount, do i need special buckets, retainers etc and can i use other style headlights, eg angel eyes?
all info welcome,
jack
#2 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 15 December 2010 - 11:37 PM
Why do you want them? I have them in my spi and have never used them.
#3 1984mini25
1984mini25
  • 8,785 posts
As far i know the self-levelling motors and stuff are part of the later headlamp bowls.
#4 pikey7
pikey7
  • 3,824 posts
Posted 15 December 2010 - 11:38 PM
they aren't self levelling. they adjust via a switch on the dash.
yes you'll need new buckets. Standard lamps should fit in them to give you options.
You'll also need the switch itself, and to add the wiring system in to make them function.
#5 jkjaxor
jkjaxor
  • 331 posts
Posted 15 December 2010 - 11:43 PM
intrested as a possible way of fitting hid lights,
do they not self level? as there described as self leveling on mini spares link
@ new buckets are these specific or just a later style plastic moulding?
cheers for the quick replys :thumbsup:
jack
#6 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 15 December 2010 - 11:44 PM
I find it peculiar that they are called self levelling though, self as in yourself!
#7 pikey7
pikey7
  • 3,824 posts
Posted 15 December 2010 - 11:45 PM
definately not self levelling no. That would require some sort of electronic sensor system which the mini doesn't have.
the bucket is a complete mechanism... bucket, motor, etc as far as the metal backing plate to which the headlamp itself fits.
the lovely quirks of misusing the English language... :thumbsup:
Edited by pikey7, 15 December 2010 - 11:46 PM.
#8 jkjaxor
jkjaxor
  • 331 posts
Posted 15 December 2010 - 11:48 PM
ahhh that clears that up then, seems trickyer than i thought, :thumbsup: thanks all
#9 TopCatCustom
TopCatCustom
    Previously known as C4NN0N.
  • 1,134 posts
Posted 16 December 2010 - 04:16 PM
Just rig it up so you hang a pendulum type thing from the roller switch you use to level them (and hide it behind the dash), then they will be self levelling if you set it up right...
#10 Bean
Bean
  • 8,054 posts
  • Name: Jean
Posted 16 December 2010 - 08:54 PM
You'll also need to cut a notch into the wing, at the bottom of the circle for the headlight - As the motor needs to fit.
#11 pikey7
pikey7
  • 3,824 posts
Posted 17 December 2010 - 04:20 AM
why not go the whole hog and set it up on a gimbal? I'm surprised no major auto manufacturer has done it reliably in such a cheap way. Oh hang on... no i'm not!
Headlights are a safety system for both you and other drivers. They can also be a major hazard if fitted incorrectly. I understand you're trying to help, but please, it's dangerous.
Edited by pikey7, 17 December 2010 - 05:08 AM.
#12 TopCatCustom
TopCatCustom
  • 1,134 posts
Posted 17 December 2010 - 10:31 AM
I said if it was set up right...
