Fuel Consumption
13 replies to this topic
#1 Green-Chameleon
Green-Chameleon
  • 279 posts
Posted 18 December 2010 - 03:23 PM
I have got roughly 55.1 miles out of half a tank.
It cost around £35 to fill up a 7 Gal tank.
Does this sound right to anyone? It is a Rover mini 35 1275.
Edit - Wow, just seen the major typo on the title. Sorry folks.
Edited by Shifty, 19 December 2010 - 04:02 PM.
#2 coopdog
coopdog
  • 4,506 posts
Posted 18 December 2010 - 04:15 PM
my friend has the same thing
its a 35 too
#3 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 18 December 2010 - 04:41 PM
Unless my maths is very wrong then 55.1 miles/3.5 gallons = 15.74 miles per gallon.... which isn't at all good!!
Is it actually half a tank though, or are you relying on the notoriously inaccurate mini fuel gauge to tell you where "half" is. According to my gauge, my mini uses the 1st quarter of a tank to do about 130 miles then burns through the remaining 3/4 over the next 50 or so!! Better to fill it up to the top, then take the mileometer reading, then fill it up to the top again after a set amount of miles (say 100 to make the maths easy) & then calculate exactly how many litres you have used and your actual MPG!
Edited by AVV IT, 18 December 2010 - 04:42 PM.
#4 pikey7
pikey7
  • 3,824 posts
Posted 18 December 2010 - 04:43 PM
Sounds excessive. Especially as the first "half" is the big half.
Has it been tuned recently? Does the oil smell of petrol? Is the overflow pipe ok? Is the fuel cap leaking? Are the fuel lines in good nick?
#5 Carlos W
Carlos W
  • 10,114 posts
Posted 18 December 2010 - 04:45 PM
To be fair, my 52 plate mondeo doesn't use each 1/4 of the guage equally, does about 500 on the first half, and 200 on the second half!
As AVV IT says, the only way is to fill it until it clicks, do a set mileage, and fill it again then do the maths!
#6 Green-Chameleon
Green-Chameleon
  • 279 posts
Posted 18 December 2010 - 08:18 PM
Well, When we first got it we put around £32 in which only got us to around half full. So I assumed I had half a tank more than the gauge was telling me... until the beginning of this week when the gauge showed nothing and I broke down.
I then filled it up to the click and 6 days and 55miles later I'm half a tank down.
#7 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 18 December 2010 - 08:22 PM
ive got the same problem except im doing 9-10 mpg i cant find a problem so going to southam minis to see if they can find the problem :/
#8 pikey7
pikey7
  • 3,824 posts
Posted 18 December 2010 - 08:23 PM
£32 and half full, then 55 miles and you broke down? You've got a serious problem there.
#9 Carlzilla
Carlzilla
  • 1,907 posts
  • Local Club: Splinters Mini Club
Posted 18 December 2010 - 08:24 PM
i can only just about fit 27quid in my tank from bone dry, its a 7.5gal
my fuel doesnt last long either, i must put a tenner in a week and do less than 30 miles on average
#10 wmc1
wmc1
  • 88 posts
Posted 18 December 2010 - 08:32 PM
I do roughly 100 miles a week (work and back) and costs me about a tenner, and I'm running a Weber.
#11 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 18 December 2010 - 08:52 PM
Thats very wrong. At current prices, thats roughly 22 litres. A 7.5 gallon tank is around 34 litres.
So your gauge is out. And your consumption is very high aswell, a tenner should get you alot mroe than 30 miles.
#12 Cooperman
  • 23,325 posts
Posted 18 December 2010 - 11:43 PM
Do a propr consumption test. Brim fill it and note the mileage. Drive it for a while until it reads nearly empty, then brim it again. Then you can measure the actual consumption. Mini gauges are so inaccurate.
Edited by Cooperman, 18 December 2010 - 11:43 PM.
#13 AVV IT
AVV IT
  • 6,122 posts
  • Name: Dave
Posted 19 December 2010 - 11:12 AM
Well no, you don't have to drive it until nearly empty at all. All that matters is that you brim fill it the first time & take note of the milage then brim fill it again at some point on that tank of fuel, taking note of the new mileage, along with the amount of fuel needed to brim fill it again. It doesn't matter if you have used one gallon or seven as you are calculating miles per gallon, not miles per tank!(& if you really want to know the miles per tank you just multiply the MPG by seven!!....)
#14 Cooperman
  • 23,325 posts
Posted 19 December 2010 - 03:59 PM
Absolutely correct, I was just thinking that it saves another stop if you run it until the point when you think it needs a good drink, but of course, if you want a quick answer, just do 30 to 40 miles before brimming it a second time. Either way you get the actual consumption. I also have a Rover 214 which holds 11 gallons. It reads 3/4 full when brimmed and empty when it still has 5 gallons in. I zero the trip when I fill it and fill again after it's done 250 miles.
