1380 Block?
16 replies to this topic
#1 josh.evans
josh.evans
  • 1,439 posts
Posted 19 December 2010 - 08:16 PM
im after a 1380 block anyone got a good condition one?
josh
#2 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 19 December 2010 - 08:18 PM
as if iu was about to post the exact same thing lol
#3 josh.evans
josh.evans
  • 1,439 posts
Posted 19 December 2010 - 08:25 PM
you dont need a 1380 you already have a 1293 :)
#4 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 19 December 2010 - 08:27 PM
ya lol need a 1380 for the blue 1991 city :lol:
#5 leaky
leaky
  • 6,890 posts
Posted 19 December 2010 - 08:32 PM
I thought you wanted to turbo the blue one as you wernt doing that to the clubby?
#6 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 19 December 2010 - 08:35 PM
ya 1380 turbo :crazy:
#7 1984mini25
1984mini25
  • 8,850 posts
Posted 19 December 2010 - 08:40 PM
And I’m sure you had a topic wanting to do a 16v head conversion.
Personally I’d be sorting out the rotten body first, but then I like to do things backwards.
#8 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 19 December 2010 - 08:44 PM
ya relised how much they cost and how much machining the head block needs so just gonna stick with 100% mini engine and would like the block so i can slowly build it up while doing the body at the same time
#9 leaky
leaky
  • 6,890 posts
Posted 19 December 2010 - 09:20 PM
Right this has gone slightly OT. But Danny your probably best going for a 1275 turbo. I had a convo with Prawn a while back and he knows about all these things. But its harder to get the compression down on a 1380. Not impossible though. Its your mini, your money and and your choice so do what you want. Have you been on Turbo Minis? If not I recommend you sign up. Some of the people on their will be able to give you some really good advice. Your best to have a full picture of what you want to do and whats the best parts for your build before to start spending money on things. You could also give Prawn a PM. He's a good chap and I'm sure he'll give you some advice. The other person that may be able to help you is mini mad69. He's planning on turboing his 1380 at some point.
Anyway I look forward to seeing what ever it is you do.
#10 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 19 December 2010 - 09:28 PM
hmmm ok thanks for the info im on turbo minis at the mo ill ask them the best size engine for turboing im glad you told me as i might have spent all that money and not get much compresstio thanks danny
#11 josh.evans
josh.evans
  • 1,439 posts
Posted 19 December 2010 - 09:31 PM
i think many will tell you that 1293 is the best for turbo and cheers for spaming my wanted thread hehehe :)
#12 1380sprint
1380sprint
  • 167 posts
Posted 19 December 2010 - 09:32 PM
My brother built a 1380 turbo, about 9 years ago, machined a little off the crown on the top of the piston,and took the head out to 30cc or something, got the comp ratio down fairly low,
At the time i had a standard MG Turbo,F-reg, and to be honest i thought that it was imensly fast, but when he finished the 1380, it was a whole differnt thing!
really went well,before it got stolen.
it can be done, even easyer nowdays, with mappable ignition etc,
But i wouldnt do it as Decent 1275 blocks are running low on the ground, so if you go 1293,then 1330, then 1380,
thats only if you kill it first time around....
you can ,make the gains elsewhere....
#13 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 20 December 2010 - 08:56 AM
I have a fresh MG Turbo block machined to 1380 with new pistons and rods. All caps present new CAM bearings - juist need a crank for a short engine (which I can supply)
How deep are your pockets?
#14 1380sprint
1380sprint
  • 167 posts
Posted 20 December 2010 - 09:22 AM
See, i'd never have a block machined unless i know exactly what size pistons were going in, ie take the block and pistons to the machine shop and they will measure and Rebore the correct size,
Not all pistons, and bored blocks are equal.
#15 dave-r5
dave-r5
  • 317 posts
Posted 20 December 2010 - 01:04 PM
how much for the short engine minus the crank mr mk3 coopers s
Edited by dave-r5, 20 December 2010 - 01:05 PM.
