Gearbox Case To Engine Torque Setting
2 replies to this topic
#1 mk=john
mk=john
  • 1,167 posts
  • Local Club: Milton Keynes Mini Club, Mini Cooper Register
Posted 19 December 2010 - 09:23 PM
Hi
I have mounted my gearbox to my engine, and can see in the Haynes manual that the torque setting should be is 8Nm for all of the bolts and two nuts at the rear.
I dont have a torque rench that can measure as low as 8Nm. Instead, I have given each fixing one firm lever (about 3 flats) with the spanner after the spring washers were compressed. I hope I havn't over-torqued them.
How critical is the torque setting for these? If it is critical, where can i get a torque wrench that measeures such low torque settings?
John
#2 1984mini25
1984mini25
  • 8,784 posts
Posted 19 December 2010 - 09:31 PM
8nm is only really hand tight with a spanner anyways. As long as your not using a long bar on them and over tightening them that way, it should all be fine.
#3 Cooperman
  • 23,294 posts
Posted 20 December 2010 - 05:20 PM
I've never torqued them up with a torque wrench and never had a problem. Just 'nip 'em up tight' and it'll be fine.
