Heater Not Blowing Warm
#16
Posted 22 December 2010 - 07:24 PM
#17
Posted 22 December 2010 - 09:10 PM
the engine has not overheated in a long time, even 2 days ago on a long drive, it didnt overheat until the morning after i pulled the matrix and pipes out (this morning). if i dont get into work tomorrow, i will give it another go.
#18
Posted 22 December 2010 - 10:48 PM
#19
Posted 23 December 2010 - 10:04 AM
#20
Posted 23 December 2010 - 10:13 AM
any quick way of checking the water pump rather than pulling it off.
Not that I've ever discovered, unfortunately it tends to be a case of drain the system & take the radiator out & fan belt off just in order to get to it. Make sure that you have a new gasket for refitting it (even if you put the old pump back in) & take the opportunity to replace the bypass hose (if you have one) whilst you have the water pump off!
#21
Posted 23 December 2010 - 01:14 PM
#22
Posted 29 December 2010 - 11:53 PM
#23
Posted 02 January 2011 - 05:48 PM
#24
Posted 02 January 2011 - 07:05 PM
I've got no heating either.I Took the hose off the righthand side (as you look at it) off the after market inlet manifold & blew down the pipe & water came out of the manifold. So i take it that the pipes aren't blocked.
That really depends on how your manifold has been plumbed in (which could be in a number of ways, if it is an aftermarket item & also depending on the age of the car & position of the standard plumbing). Presuming your heater matrix is actually plumbed in between the pipe you have disconnected & the end of the manifold, then it is still possible that you have a partial obstruction somewhere in the heater circuit that is allowing some air to pass through, but not a significant enough amount of water to provide any real heat. It might therefore be worth flushing the heater circuit anyway if only to fully "rule that out" as the problem.
#25
Posted 02 January 2011 - 07:13 PM
#26
Posted 02 January 2011 - 07:14 PM
#27
Posted 03 January 2011 - 11:08 AM
Ok thanks. What's the best way to flush it through? Cheers
Disconnect the heater inlet & outlet pipes at the bulk head, connect a garden hose to one and a spare piece of pipe leading to a bucket into the other, turn the garden hose on and flush through, then reconnect the heater pipes again.... Simples!!! (Just don't turn the garden hose on fully though, as full mains water pressure may well blast holes in your heater matrix if it is old!!)
See this pic: Note that your heater inlet/outlet hoses may well be in a different location on the bulkhead, as this is a late HIF 38 mini & earlier models had different plumbing:
#28
Posted 16 January 2011 - 10:08 PM
