Wheel Nuts- Revolution Style Sleeved Ones- Please!
3 replies to this topic
#1 TopCatCustom
TopCatCustom
    Previously known as C4NN0N.
  • 1,134 posts
Posted 21 December 2010 - 10:28 PM
Hi, I really need to find a set of wheel nuts to fit an odd size set of alloys- they need to be sleeved like revolution type ones- but the important bit is the shank needs to be at least 17mm diameter, or 11/16" (which is thicker than the normal revo ones I think), and approx 3/4" long (excluding the hex nut part).
I'll most likely be reaming the wheels to be a perfect fit so not crucial- but they obviously need to be the normal 3/8 unf mini thread!
#2 GraemeC
GraemeC
  • 7,476 posts
Posted 22 December 2010 - 08:17 AM
You need Grayston part number SN27, but you may have to shorten them:
3/8" unf 11/16" shank sleeve nut 30mm long Part No SN27
http://www.graystone...heelnutmenu.htm
Unfortunately you can't buy direct, but they should be easy enough to get.
#3 TopCatCustom
TopCatCustom
  • 1,134 posts
Posted 22 December 2010 - 10:19 AM
Yes I saw them online but couldn't find how to buy. I'm prepared to have to shorten them or reduce the shank, just hoping someone has a set I can buy second hand!
#4 GraemeC
GraemeC
  • 7,476 posts
Posted 22 December 2010 - 06:35 PM
https://www.europasp...UTION_5594.html
