Soda Blasting In Norfolk /suffolk ?
Posted 28 December 2010 - 06:32 PM
cheers guys
lee
Posted 28 December 2010 - 06:40 PM
Posted 28 December 2010 - 06:48 PM
Posted 28 December 2010 - 09:44 PM
The only real benefits I see are that the soda doesn't damage glass, rubber etc in the slightest, but if you have a bare shell I think it's a waste of money! Only my opinion of course
it doesn't damage/mark metal when you use it, leaves a projective coating on the bare metal and generates minimal heat when using it so you don't get any heat distortion.
Posted 29 December 2010 - 05:48 PM
Posted 29 December 2010 - 06:35 PM
David
Posted 29 December 2010 - 06:48 PM
Posted 29 December 2010 - 09:34 PM
I'd never have flat panels blasted anyway, easy to take back with a DA sander, just get them to do round all the edges and the horrible backs covered in underseal etc, I've seen a car that was sand blasted all over and every door and big panel was warped to buggery, I know soda blasting shouldn't do that but I'd be happier doing it by hand anyway.
Posted 29 December 2010 - 11:52 PM
I found out that soda blasting also leaves an unreactive coat on the surface which you need to remove with some sort of acid else your paint won't stick properly.
you can just wash it off
Posted 30 December 2010 - 05:05 PM
Posted 30 December 2010 - 09:48 PM
don't bother with shiteromors.
