How To Conduct A Compression Test?
Posted 28 December 2010 - 09:05 PM
I have read the Haynes manual re: compression testing, but I just don't understand the 'have somebody hold the throttle open while you turn the engine over on the starter motor' bit?
Can anyone please right a quick 1-10 for dummies on carrying out a compression test?
Also if anyone has any thoughts on the following: I have recently replaced the primary gear oil seal, found oil in the flywheel housing, but I suspect it's leaking again, hence the compression test? Can anyone offer any advice?
Thanks for suffering a fool.
Posted 28 December 2010 - 09:40 PM
Posted 28 December 2010 - 09:45 PM
Hi, my apologies for being very stupid.
A compression test is to check for bore / piston ring wear.
A leaking primary oil seal will not be connected in any way.
Is this the only reason you want to do the test?
Regards
Steve
Posted 29 December 2010 - 08:18 AM
Steve couldn't one of the cylinders be split and pressurise the sump? Causing more pressure on the seal? Or maybe the breathers/hosing could be blocked causing the same problem?
It's not runnin great anyway, so think the test might help to diagnose any issues?
Posted 29 December 2010 - 01:41 PM
Cheers guys.
When my clutch wore out very early on due to a leaking oil seal, I took the breather canister of the flywheel housing to find that it was choked solid with crud. It was so bad that I filled one end of the breather with thinners and over an hour later still nothing had appeared at the other end. I have never seen one blocked up so bad before. I ended up poking all the wire wool out with a screwdriver and replacing it with new stuff. Since then all the other little oil drips have stopped as well.
Posted 29 December 2010 - 02:18 PM
Posted 29 December 2010 - 04:22 PM
Checked compression today and all cylinders around 165-170psi. Phew.
I bought a 'new' Clutch housing breather (seems to be a recon'd one) from minispares, as have been told as you say mike that the breather could be blocked. Tried to fit it today but with the engine steady repair kit i have it won't go back on... Frustrating to say the least. Having to find a fix for this!?
How easy is it to fill the breather back up with gauze? Because I cld just do this with my original one and get the £28 back from minispares?
Posted 29 December 2010 - 05:41 PM
Edited by bmcecosse, 29 December 2010 - 05:42 PM.
Posted 29 December 2010 - 06:15 PM
Edited by cooperrodeo, 29 December 2010 - 06:16 PM.
Posted 29 December 2010 - 06:23 PM
yes excessive crank case pressure could cause it to blow, but to be honest a compression test wont really find that - a leakdown test would be better to assertain the leakage of the cylinders and where its leaking off to.
Posted 30 December 2010 - 10:43 PM
Today I replaced the Flywheel housing breather and cleaned all pipes. I'm concerned about the timing cover breather though when engine is idling it doesn't seem to have any air pumping through it at all, compared to the flywheel housing one which has a flow constantly? Is this correct?
I tried to clean the timing cover breather but it wasn't easy. I really don't want to be replacing the timing cover if I don't have to seems like a big job! But need to reduce the pressure in the sump!
