Only One Side Light Working. No Dipped, But High Beam Works!
5 replies to this topic
#1 Pinkerton_pink
Pinkerton_pink
    Starting My Mini Up
  • 3 posts
  • Local Club: Lookin for one....
Posted 29 December 2010 - 01:03 PM
Mini Mayfair
1993
I have a problem where only the sidelight on the drivers side works. The dipped beam does not work at all on either side.
The high beam works both as flash or clicked on. Rear lights work too. All indicators etc work. Bulbs are ok
Can't find a problem with fuses etc.
Any suggestions would be great. I'm ok with mechanics but electrics confuse the hell out of me.
Had problems with brake lights and indicators which are now sorted.....
#2 charie t
charie t
  • 3,153 posts
Posted 29 December 2010 - 01:16 PM
Mini Mayfair
1993
Under the front panel where the bonnet catch is, there is a series of connerctors. these corrode causing badconnections. Clean them up and you'll have lights again, it might be easier to remove your grill too
Edited by charie t, 29 December 2010 - 01:17 PM.
#3 GAGSINIO
GAGSINIO
  • 98 posts
Posted 29 December 2010 - 01:28 PM
Might also be a knackered Fuse, had same problem last week. Fuse box should be at the back of the Engine Bay, a small, black oblong box. The previous owner of my mini had put all wrong fuse sizes in. The correct order and size is as follows(thanks Kerrin):
Top-35 Amp(this is probably the culprit)
2nd-25 Amp
3rd-25 Amp
Bottom-15 Amp
Hope this helps.
#4 Pinkerton_pink
Pinkerton_pink
    Starting My Mini Up
  • 3 posts
Posted 29 December 2010 - 08:59 PM
I'll check these connections tomorrow.... thanks. as for fuses, all present and correct....
#5 mini_newboy
mini_newboy
  • 246 posts
Posted 29 December 2010 - 09:13 PM
Check the earth connection on the back of the light. I had the same problem, side light work but main beam was really dimm, wiggle the black wire & found a bad earth, once that was fixed, everything worked like it should
Chris
#6 Pinkerton_pink
Pinkerton_pink
    Starting My Mini Up
  • 3 posts
Posted 30 December 2010 - 04:10 PM
Right today's update:
Have checked and double checked everything and now I have the following:
Side lights
High beam (both clicked on and with the flash on the stalk)
indicators
Hazards
Rear lights
Turned out I only had one sidelight before as a bulb had blown (even though I'm sure I checked before)
I have No dipped beam at all. (even bought new bulbs today to double check)
I have checked all the wires at the front behind the grill which seem fine.
I think that the problem stems between the switch (which is all good as checked with a meter) and the main feed to the headlights. So am I missing a possible faulty relay?
I replaced the main feed by the grill and hooked that directly to live and the headlights worked.
Not sure if there is any other info I can provide but this is really puzzling me now!
Any help would be muchly appreciated!
Darren
Edited by Pinkerton_pink, 30 December 2010 - 04:11 PM.
