Front Hub
6 replies to this topic
#1 Gavin Wakely
Gavin Wakely
  • 11 posts
  • Local Club: Milton Keynes Mini Owners Club
Posted 31 December 2010 - 01:51 PM
Hi I'm looking into changing my front hub geometry, but I need an accurate drawing with dimensions of a standard mini front hub. I've tried many searches but to no avail, anyone able to help ?
Gavin
#2 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 31 December 2010 - 03:26 PM
Try contacting Mini Sport, they have recently had the front hubs remade in alloy so must have some accurate drawings they may be willing to share.
#3 charie t
charie t
  • 3,153 posts
Posted 01 January 2011 - 10:23 PM
Can i ask why?
#4 Paul Wiginton
Paul Wiginton
  • 1,585 posts
Posted 01 January 2011 - 11:24 PM
Its to get the correct kingpin inclination with a 6x13" wheel
#5 Ethel
  • 26,073 posts
Posted 02 January 2011 - 01:07 AM
Z cars might be a better bet, being more of a hands on chassis building company?
The figures I know are 3 degrees castor, and 9 1/2 degrees KPI. King pin incline being the only dimension fixed in the swivel hub. The CV joint should pivot on the intersection of the kingpin axis with the axle.
Metro hubs might be worth a look; Force, make 'em in Titanium so you could ask them. You can actually alter the KPI a bit by spacing the lower ball joint, but it would decrease the angle so not much use on a Mini upright. It might be useful for fine tuning a Metro's though, and easier with their sealed joints.
Don't think I've actually seen a quoted Metro KPI, please share if you find it.
#6 1984mini25
1984mini25
  • 8,785 posts
Posted 02 January 2011 - 01:40 AM
There was an old mini mag issue were they went thorough and compared the geometry of using metro hubs and mini hubs and what the effects were, I’ll see if I can find it…
#7 1984mini25
1984mini25
  • 8,785 posts
Posted 02 January 2011 - 05:16 PM
I found it (June 2010 minimag issue 173) but it doesn’t go into as much detail as I thought.
All I can find from it are the ball joints centres are half an inch further apart bellow the hubs centre line. And that the camber changes from 5/8 positive on mini hubs to 1.1/4 inch positive on the metro ones.
