Top Susp Arm Swivel Joint Hell
Posted 31 December 2010 - 02:04 PM
Am trying to get the engine out and am totally stuck at the final hurdle, top swivel joints on the upper suspension arm on both sides is completely stuck, as is the drivers side steering rack ball joint.
I've soaked it in penetrating oil and screwed the G-clamp ball joint splitter into the original nut followed by whacking the cr8p out of it with a mallet.
I'm thinking the next step is to apply some heat but I don't have a blow torch, can anyone recommend which type and where from, don't want to spend a fortune on it but I know i'll probably need it again before too long.
Also once I've obtained said blow torch which parts do I apply heat too and for how long?
Also open to any other suggestions!
Cheers guys,
Desperate Dan
P.S I'm at the point where the grinder is looking like a feasible option...
Posted 31 December 2010 - 02:11 PM
Argh, I've read a couple of similar posts so apologies for the same old same old.
Cheers guys,
Desperate Dan
My (somewhat unorthodox) method was to support the top arm on a crow-bar that was resting in two axle stands...
Then I whacked the joint with a lump hammer...
Popped straight out...
Posted 31 December 2010 - 02:24 PM
http://www.machinema...l-joint-remover
tighten it up and then if it still wont pop out hit the arm with two heavy hammers on opposite sides at the same time.
good enough to pop out ball joint on a landy and they only have one torque setting -FT ( that's not FAIRLY tight)
G
Posted 31 December 2010 - 02:34 PM
I have read on here that some people don't even touch the ball joints when removing an engine. I can't remember exactly how it's done but might be worth a search...
Posted 31 December 2010 - 03:13 PM
Posted 31 December 2010 - 03:35 PM
Posted 31 December 2010 - 05:28 PM
You don't need to split any ball joints to get the engine out of the car...
You don't need to split inner CV joints to get the engine out of the car...
With a little thought they come out real easy with a lot less stress and less possibility of bits falling off later
It is done thus.....
Remove the all the bits as you would normally do.....
DO NOT remove hubs etc......
DO remove engine mount bolts and get ready to lift the engine, at this point you will need either a CV releasing tool or a large lever.
NOTE! Left or Right is viewed from the drivers seat whilst seated.
lift the engine about 1" (25mm) and slide over twards the left hand side (radiator side), now "crack" the inner CV from the gearbox, you can now wriggle it free and drop it down under the gearbox.
Now push the engine unit towards the right hand side (clutch side) and "crack" the LHS inner CV from the gearbox, you can now wriggle it free and drop it down underneath......
It is now possible to lift the whole unit out as far as the split line (this is the line where the gasket joins the engine and gearbox) as far as the slam panel.... now disconnect the speedo cable
Edited by mra-minis.co.uk, 31 December 2010 - 05:38 PM.
Posted 31 December 2010 - 07:24 PM
Posted 31 December 2010 - 08:30 PM
Posted 01 January 2011 - 11:39 AM
Yes I forgot to mention the oil
Posted 01 January 2011 - 02:40 PM
just has the right amount of bend on the last 1" and small enought to get in the gap to pry the pot out.
Posted 01 January 2011 - 03:10 PM
This actually works. Like magic!
Edited by Bramham89, 01 January 2011 - 03:11 PM.
