Fitting Duplex Timing Chain
5 replies to this topic
#1 Joe555
Joe555
  • 240 posts
Posted 02 January 2011 - 02:43 PM
1989 1275cc Metro engine.
What mods do I need to do to the timing chain cover to fit a duplex timing chain. Does the bit of metal inside the breather need to be removed????
Joe
#2 mars red mike
mars red mike
  • 1,500 posts
Posted 02 January 2011 - 02:49 PM
From what I remember there is a small inward facing lump next to the hole where the crank comes through. This needs tapping flat. There is also a round metal piece around the breather hole that I gorund off. Not sure if it needs to come off but I did anyway.
#3 Cooperman
  • 23,326 posts
Posted 02 January 2011 - 02:51 PM
There are 3 things you need to do:
1. Remove the 'lip' inside the timing cover.
2, Countersink the engine front plate where the 2 off 1/4" UNF bolts are fitted and replace these bolts with 1/4" UNF x 5/8" long socket head countersunk screws, using Loctite to ensure they won't come loose. Use a correct countersinking tool, not a large drill, as the angle of the countersink needs to be correct.
3. Remove the chain tensioner and fit 5/16" UNF bolts to fill the redundant holes.
Check the accuracy of the cam timing using a 360 degree engine protractor and a dial gauge. Correct any error with offset woodruff keys. Some after-market timing chain sprockets are not particularly accurate. If you have a standard Austin-Rover cam, the correct timing is 110 degrees ATDC on the inlet valves.
In hope this helps.
Edited by Cooperman, 02 January 2011 - 03:10 PM.
#4 mars red mike
mars red mike
  • 1,500 posts
Posted 02 January 2011 - 02:53 PM
Oh yeah. Dont forget to fit a new crank seal and make sure that you fit the oil thrower the right way around.
#5 Cooperman
  • 23,326 posts
Posted 02 January 2011 - 03:13 PM
To add to what 'mars red mike' said, if your cover has the indentation adjacent to the lip which you are to remove, this does need to be knocked out with a ball-ended hammer. I think those earlier covers may not have this though, but I could be wrong.
#6 Joe555
Joe555
  • 240 posts
Posted 03 January 2011 - 10:06 AM
Thanks for the help.
Joe
