Please Help For A Spi Conversion To Carb
3 replies to this topic
#1 minifan333
minifan333
  • 72 posts
Posted 04 January 2011 - 05:04 PM
Good evening.
I bougth from minimania a kit conversion
from SPI to carb.
I need only one thing..the electrical scheme of SPI
ECU plug.
I found a good how-to but without schemes.
http://www.minimania.../SCatagory/FUEL SYSTEMS/DisplayType/Technical Information/DisplayID/1668/ArticleV.cfm
Someone can help?
#2 bmcecosse
bmcecosse
  • 9,699 posts
Posted 04 January 2011 - 05:45 PM
Your not going to use any of the ECU - just wire up ignition as in any normal carb Mini.
#3 minifan333
minifan333
  • 72 posts
Posted 04 January 2011 - 07:57 PM
In how-to their wrote "The wiring diagram included in this kit shows connecting from the ECU plug terminal 11 to terminal 85"
What is terminal 11?
#4 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Posted 05 January 2011 - 12:38 AM
Hi,
From what I can determine using the Haynes diagrams this is what you have:
terminal 11 black wire with white tracer (ignition switch power 12V)
terminal 4 white wire with purple tracer (main relay coil earth path - ignition coil power 12V feed)
terminal 20 black wire with purple tracer (fuel pump relay coil earth path)
It appears that you will still be using the SPI relay module.
Hope that helps,
Ivan
