I present my two mini
the black one is a 1340 mini standard and the farina grey is my new pro-mo project
Posted 04 January 2011 - 06:30 PM
Posted 04 January 2011 - 07:58 PM
Posted 04 January 2011 - 08:21 PM
Posted 05 January 2011 - 05:48 PM
Posted 06 January 2011 - 09:18 AM
Posted 06 January 2011 - 02:52 PM
Posted 06 January 2011 - 03:00 PM
Thank you and nice to meet you !
if you don't use the EXUP what do you do with the "outlet" ?
Posted 09 January 2011 - 06:54 PM
Posted 10 January 2011 - 09:56 AM
thank you very much, I also wanted to know how did you do to the oil pressure and
water temperature and oil?
I have no dashboard R1 so I need to branch the gauge independently
if anybody have a solution....
Posted 10 January 2011 - 10:15 AM
Posted 29 January 2011 - 06:30 AM
water temperature is done with an in-line insert to the top radiator hose...............
oil pressure and oil temperature is done by using a sandwich plate between the oil filter and the block - screws into place and then you have two insert points for sender units.
both are available on ebay but make sure you get the right sizes......oil sandwich plate I think is M14.......
Posted 30 January 2011 - 09:08 PM
Posted 13 February 2011 - 08:28 PM
Posted 13 February 2011 - 08:36 PM
Posted 13 February 2011 - 09:52 PM
