Mpi Radiator Dimensions
Posted 06 January 2011 - 09:22 PM
Basically, i have a mini with a vaux conversion but my radiator has split and needs replacing and it is not a vaux rad so after raiding the net for a couple of months a think that it may be a mini MPi radiator but dimensions are critical as it cant be bigger then my current rad as it wont fit..... So if anyone would be able to supply me with the core dimensions i would be most greatfull...!
The MPi rad itself is here if you require a pic at all: http://www.minisport...nfo_GRD974.html
Minisport couldnt supply me the dimensions as they are factory packaged so it would save me and them time if i was able to aquire the dimensions before purchasing so that i dont have to return the rad if need be......
Thanks in advance!!!
Posted 06 January 2011 - 09:46 PM
Basically you want to know if you can replace yours with a mpi radiator?Hi, i was just wondering whether or not any one would be able to supply me with the MPi front mounted radiators core dimensions?
Can you post any pictures of yours up?
I'll see if i can dig the tape out tomorrow and measure mine
Posted 07 January 2011 - 01:08 AM
[/quote]
um, kinda... i think mine may already be an MPi radiator as i read that with some vaux conversions they use them... but i dont know for sure as i bought the car already converted... and now as the rad has gone, i need to replace it but dont know what its from... so just trying to figure it out really lol. It looks identical to the MPi rad, but atm its had a temporary repair but could do with replacing so when i get a chance to measure mine again i will... as for pics... ill have to remove it to get some pics worth while... dont worry, im in no major rush, just want it sorted for show season
Cheers, your help will be much appreciated!
