Rear Wheel Bearing Help!
Posted 07 January 2011 - 07:30 PM
I'm pretty new to mini's and currently rebuilding a new subframe for my restoration. Ive fixed in the radius arms and just wanted to change the wheel bearings. I removed the old ball type bearings and knocked out the old inner races, fitted the new inner races and dropped in the new taper bearings.
When i tightened up the hub nut just finger tight it was quite hard to move the hub. very stiff. I have had it all to bits a few times, tried different bearings (which were supposed to be for the other side!) and still the same, I've made sure the oil seal is in correctly and that the washer is on the right way but still very stiff, I havent even tried to tighten to correct torque setting as theres no chance the hub would move.
When fitting taper bearings to the rear do you remove the spacer out the hub for the old ball type bearings? Everything looked the same size before I fitted it.
Any help would be much appreciated! I've looked at other similar links but couldn't find one to answer my question.
cheers
Russ
Posted 07 January 2011 - 08:26 PM
Hi all,
cheers
Russ
Posted 07 January 2011 - 08:29 PM
Rear wheel bearings don't get tightened up, only the play is taken out of them.Hi all,
cheers
Russ
Being a thick <<<>>> i cant exactly describe how to check correct adjustment on here, but the play in the wheel will only just be taken up when the nut is turned, and the wheel will still spin freely
Posted 07 January 2011 - 08:46 PM
Posted 07 January 2011 - 08:51 PM
Trailers done it for years as have mini's. The split pin stops the nut undoingthat did cross my mind but its the hub nut that needs tightening, you can't really leave that just a bit more than hand tight can you?
Posted 07 January 2011 - 10:04 PM
Posted 07 January 2011 - 10:38 PM
Posted 07 January 2011 - 10:54 PM
Posted 07 January 2011 - 11:03 PM
Probably not..... the kits without spacer are designed to replace existing taper bearings.........
Thats what I thought, I'm doing something wrong then, when I nip the hub nut up it wont move at all, both races are tight up against the spacer aswell, no gaps.
Posted 07 January 2011 - 11:08 PM
Posted 07 January 2011 - 11:10 PM
front/rear mix up here i thinkProbably not..... the kits without spacer are designed to replace existing taper bearings.........
Posted 07 January 2011 - 11:18 PM
Posted 07 January 2011 - 11:25 PM
Then tighten the nut up tight and fit the split pin. As 'bmc...'says, too stiff and the spacer is too thin, too slack and the spacer is too thick. It's easy to correct if slightly too thick - just linish a bit off the spacer. If too thin, you need a thicker spacer.
Posted 07 January 2011 - 11:32 PM
To fit taper roller rear bearings, there has to be a spacer appropriate to the bearings. The original one for the ball bearings may not be thick enough.
Any ideas where I could get a thicker spacer from?
