Engine Stalling When Changing Gear (coasting)
Posted 09 January 2011 - 09:40 PM
The 1275 ticks over fine when not going anywhere but I have noticed it will stall if i change gear a bit slow or put clutch in to coast at all even when changing to reverse. Is it likely it is running a bit week. I'm on the isle of man so no rolling road!
Posted 09 January 2011 - 09:47 PM
is there a judder as clutch is engaged?
check your mixture strength!! common one! as i said dont know if this would only happen when depressing clutch pedal.
let me know
Posted 09 January 2011 - 09:52 PM
Posted 09 January 2011 - 10:00 PM
fngers crossed mate
Posted 09 January 2011 - 10:12 PM
Have you tried pulling the choke out and seeing if that changes anything?
that could help you determine if it's a fuelling issue, which it sounds as if it could be!
Posted 09 January 2011 - 10:15 PM
Posted 09 January 2011 - 10:21 PM
they can quite easily be pulled off with out noticing and cause some funny running issues
Posted 09 January 2011 - 10:34 PM
the other thing i'd look at is to make sure the little advance/retard vacuum hose is still going from your distributor to your carb.
Thats still nicely attached, makes a change lol
Posted 10 January 2011 - 11:57 AM
Posted 10 January 2011 - 12:09 PM
So, if you're stationary, the car is idling perfectly happily, you press the clutch and it stalls... ?
What makes you think it's a problem with the mixture ?
If the above is true, then there's a couple of possibles.... the clutch release bearing is seized which stalling the engine, but this would normally be accompanied by a high pitched squeal, or your crank thrust bearings are ******* and the friction being applied to the crank by disengaging the clutch is stopping the engine...
To check the crank end float, when the engine is off, push the crank using a suitable lever from the pulley end, then with the aid of an assistant and a DTI, measure how much the crank moves laterally when the clutch is pressed..
Posted 10 January 2011 - 12:19 PM
Posted 10 January 2011 - 03:49 PM
Posted 10 January 2011 - 04:23 PM
hope its all good now
