Rear Side Opening And Non Opening Windows
6 replies to this topic
#1 jamie@thefatgarage
jamie@thefatgarage
  • 120 posts
Posted 10 January 2011 - 03:52 PM
Is the glass on opening and non opening rear windows the same? Is it a case of removing the opening metal gubbins and changing the rubbers to convert from opening ones to fixed ones?
P.S. I need a full set of door seals, boot seal and window seals if any of you traders would like to sell me any when I have the answer to the above. I'd prefer to get them from you guys than anon traders on ebay.
#2 stevede
stevede
    As seen on TV
  • 1,164 posts
  • Local Club: None
Posted 10 January 2011 - 04:00 PM
The glass is a different size so whilst what you suggest is a good idea, it won't work.
#3 [email protected]
[email protected]
    Minispares
  • Minispares
  • 3,231 posts
  • Name: Simon Jackson
Posted 10 January 2011 - 04:03 PM
As above, it won't work. We stock a full range of all of these rubbers also
#4 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 10 January 2011 - 05:51 PM
Easiest option is to stick an ad on here suggesting a swap, as people with sealed windows often want to swap for openers ("the grass is always greener" and all that!!)
For rubber trim I would give "Phoenix Supplies" a call, they have a trade stand on the "mini show" circuit over the summer so you may have seen them around. They seem to stock every conceivable type of trim & rubber for the classic mini & they also seem to be a lot more competitive on price than anywhere else I've tried. They're based in Devon so they are hardly local to you, but they do have reasonable P&P rates. (email: [email protected] or Tel: 01884 849294)
#5 jamie@thefatgarage
jamie@thefatgarage
  • 120 posts
Posted 10 January 2011 - 06:19 PM
thanks for that I'll give them a try
problem with a swap is the opening windows i have are not in good nick, the metalwork is corroded. I think I'll tart them up a bit and use them until I decide what to do...
#6 stevede
stevede
    As seen on TV
  • 1,164 posts
  • Local Club: None
Posted 10 January 2011 - 06:22 PM
I got mine for not a lot off flea bay.
Are you going to Bingley? maybe some there.
#7 AVV IT
AVV IT
  • 6,122 posts
  • Name: Dave
Posted 10 January 2011 - 07:01 PM
Also you end up with no windows whilst you wait for each others windows to arrive in the post!! :thumbsup:
