Rover Mini Cooper Sport 1.3 (2000) Problem Installing New Wipac Front Spotlights
Posted 10 January 2011 - 05:07 PM
red full black leather full k & n sports gearbox sports exhaust
hi all users am new to the forum and in need of some major help with my new wipac front spotlights i have no idea how to install them as the previous cables i have in my car to power the lights have 2 ends and the new lights have 1 cable coming out!!!! so all in all i have 8 cables coming from the car and 4 cables coming front the spots?? any thoughts that could be helpful will be much appreciated thanks redminifish!!
Posted 10 January 2011 - 05:31 PM
Posted 10 January 2011 - 05:33 PM
Please check that a relay has been used and the circuit is fused correctly
Plenty of threads & diagrams about wiring spotlamps if you have a quick search
Posted 10 January 2011 - 05:57 PM
Just for your own peace of mind if you are using existig wiring.
Good advice for 3rd party wiring, however this chap sounds as though he has original rover wiring, which will have all the fuses & relays already there. Just make the connections at the grille end.
Posted 11 January 2011 - 12:38 AM
i have a new problem now shock from a mini! but my heating will not heat up at all it pumps air out but will not pump hot air out any ideas why this is happening mini madmen?!?!? all the best redminifish
Posted 11 January 2011 - 07:29 AM
Heater valve has ceased in the closed position. On your 2000 MPi, the valve will be under the dash rail, to the left side of the heater. You need to get your head into the footwell to see it...i have a new problem now shock from a mini! but my heating will not heat up at all it pumps air out but will not pump hot air out any ideas why this is happening mini madmen?!?!? all the best redminifish
If you are lucky, you can just work the arm back and forth without disconnecting it, otherwise you need to remove, work manually or replace (expensive for an MPi...)
if you are, check that the pipes going into the car are getting hot. if they aren't there's something wrong.
Posted 11 January 2011 - 07:56 AM
Good point minispaniard.Are you pulling out the heater cable? (I think it's pulling on the later ones...)
Redminifish - do you know which knob to pull? (snigger)... pull out for heat:
Edited by L400RAS, 11 January 2011 - 07:57 AM.
Posted 12 January 2011 - 10:21 PM
thankyou for your graphic picture i was puzzled with what that nob was i just thought it was for the misses lol! the switch at the back connected to the cable does not feel like its doing much moving and the pipes going from the engine are hot but that could just be the heat from engine heating them?!? also my dashboard clip which holds the top in above the lights is broken so dash is slagging a bit is there a straight replacement available or any other suggestions to get around this matter? thanks agen redminifish
