Carb Bushes
Posted 10 January 2011 - 08:19 PM
and how much is enough play on the spindle??
Cherrs
Posted 10 January 2011 - 08:39 PM
Posted 10 January 2011 - 08:50 PM
Posted 10 January 2011 - 09:04 PM
Posted 10 January 2011 - 09:20 PM
but drilled and then used a press to get new ones in ^^ thank god i go college
Posted 10 January 2011 - 09:22 PM
The emissions went off the scale within 5 seconds.
I put it into a garage to get the engine/fuelling sorted as it kept stalling after the 'so called mechanic' I had employed previously left it on a condition where it would stall every time the throttle was released when stopping the car.
He told me the carb was very worn, But had set it up so that it would run continuously.
He also told me that the HS4's wear was in the spindle where it goes through the carb.
The car was still on the ramp and he showed me the wear.
I found that I could literally wiggle the spindle near where the throttle cable and return spring are mounted.
The mechanic (who is a mini fan - he had three and had just returned from a big mini event) told me that if I cold feel any movement, then it is too worn!
The problem was when the throttle was pressed, the spindle with the butterfly valve would move, but when it was released, it the spindle and butterfly valve would come to rest in a different position each time. This would affect the tick-over and the car would run rough or stall. Also, the wear would cause an air leak into the carb further upsetting the mixture.
Fortunately, I bought a stage 1 kit off ebay and a HIF carb was included.
He told me to bring the car back with that carb and he would fit it.
He also told me that he preferred the HIF as it has a return spring on both sides and reduced the 'stress' on one side of the carb as in the HS4, so wouldn't suffer as much.
He fitted the HIF and the car has run fine since.
I did enquire as to having the carb rebushed, but he told me that the carb would need to be sent off and was not going to be cheap as it was quite an involved job to do.
As I had another carb, I didn't go any further with HS4 rebushing.
Also the car was needed on the road ASAP.
Edited by Brigbeale, 10 January 2011 - 09:31 PM.
Posted 10 January 2011 - 09:27 PM
http://www.sucarb.co...tail.aspx?id=27
Posted 10 January 2011 - 09:33 PM
Posted 10 January 2011 - 09:47 PM
sounding right the carbs die off and the engine stalls
so i was thinking are the bushes gone when i
or has somebody come across this problem before
Cherrs
Posted 10 January 2011 - 10:16 PM
Also check this
Posted 10 January 2011 - 10:27 PM
i have richened the mixer because it backfires thru the carb
so do you think that i should lean off
Posted 10 January 2011 - 10:42 PM
Quite possibly, spitting back can be a sign of weak mixture. Have you filled the dampers with oil?Thanks tommy,
I would get it to running temp and try lifting the pistons as shown in the video. You only want to lift them about 0.8 mm which is difficult when using the lifting pin as its hard to tell when it contacts the piston and then gauge how far you have lifted it. This is why the guy in the video uses a small screwdriver. Stick at it, if the engine revs increase when you lift the piston then it is too rich, if they fall then you should richen some more.
Posted 11 January 2011 - 01:44 PM
Be careful if using a drift as some SU's have moulded in bushes, drifting them out can result in damage to the carburettor body.
Also some of the bushes now available are not a direct replacement for the original sizes.
It really is best to ream out the old bush using a fixture to hold it all square and true, impossible to obtain with a hand reamer
The more slack you have around the butterfly spindle shaft the more air is drawn in which effects your mixture, this is bad enough, however if you have a "blow through" turbocharged or supercharged system this can allow fuel to leak out. Even with the Metro & ERA turbo carburettors seals fitted they can still leak if the shaft wear is excessive.
