my minis got a leak im 99% sure its the door seal it only leaks when i wash it and ther is soap and water on the iner seal. how do i change the seal? and where can i get them from?
thanks.
Door Seals (leaking)
joel93
, Jan 12 2011 12:21 PM
3 replies to this topic
Posted 12 January 2011 - 12:21 PM
Posted 12 January 2011 - 12:33 PM
any of the major suppliers will have door seals, they literally just pull off and pusk back on, using a rubber mallet to tap it home nice and tight helps too. I always get mine from phoenix supplies at shows, but thats just force of habbit now lol
Posted 12 January 2011 - 07:33 PM
Are you sure its the door seal.
Something else to check :
I get water on my door seal on the inside, but its from a drip that comes through the windscreen seal, then drips off and onto the door seal on the inside.
Edited by Cerberus, 12 January 2011 - 07:34 PM.
Posted 12 January 2011 - 07:57 PM
what year it mine leaked alot of water before i restored it and i was convinced it was the doorseal but turned out to be a hole under the rubber seal which caused it to run down the bulkhead and into footwell
