Fitting Sump Guard To Auto Mini
9 replies to this topic
#1 minimanjay
minimanjay
  • 230 posts
Posted 12 January 2011 - 07:08 PM
Having problems with fitting sump guard to a auto mini Mayfair 1990 please help seems that the sumo hangs too low and the guards like 2/3 incus away from the frame x
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 12 January 2011 - 07:22 PM
a auto gear box is bigger than a manual and as sump guards are a rally thing they are designed for a manual box
post some pictures up and someone might think of a solution
#3 Cooperman
  • 23,320 posts
Posted 12 January 2011 - 07:25 PM
I've ever only fitted a sump guard to rally cars and would never use an auto for competition. If you are in danger of hitting the sump, why not just raise the suspension to get a bit more ground clearance?
#4 icklemini
icklemini
  • 2,982 posts
Posted 12 January 2011 - 08:03 PM
If you are determined to fit it - then you'll have to make up suitable spacers to 'lower' the sumpguard down so it clears the auto box.
#5 maggies_minder
maggies_minder
    TMFs New official Spamster
  • 4,393 posts
Posted 12 January 2011 - 08:09 PM
i noticed this on a friends auto and at first i was confused as to why i could see the sump from in front of the car even with the reg plate on.
the sump hangs much lower down. you sump guard will become a connector for a scale-electrix car.
you'll have you mini riding really high.
#6 minimanjay
minimanjay
  • 230 posts
Posted 12 January 2011 - 10:48 PM
I no that's the reason I want to put it on due to how low it is because speed bumps seem to scrape it ;)
#7 bmcecosse
bmcecosse
  • 9,699 posts
Posted 12 January 2011 - 10:59 PM
Well - the guard will REALLY hit the bumps. You could end up 'stranded' with the tyres off the ground. ;) As others have suggested - raise the suspension, and perhaps fit larger diameter wheels/tyres ?
Edited by bmcecosse, 12 January 2011 - 11:01 PM.
#8 ShoutforJoy
ShoutforJoy
  • 738 posts
  • Local Club: TMF+, Automatic Mini Register
Posted 13 January 2011 - 06:45 AM
I no that's the reason I want to put it on due to how low it is because speed bumps seem to scrape it >_<
This isn't a common problem with automatics - they're usually OK with speed bumps. As has been said adding a sump guard could make the situation worse.
Has your mini been lowered in some way? If it has then it probably needs to be lifted a little. If not then I would say that you need to look at the suspension for wear.
#9 MRA
MRA
  • 7,607 posts
Posted 13 January 2011 - 10:24 AM
I have a customer who rallies an automatic...... it is something you have to endure if you want a sump guard.... the chances are that it is lower than standard due to sagging doughnuts on your suspension.
#10 minimanjay
minimanjay
  • 230 posts
Posted 14 January 2011 - 09:56 AM
yh i have changed the donuts on the fornt what a bugger they were to ge tin and i put hi los in and higherd it a tab as well
