Hi guys im confused on which order i put my leads on. My old ones say from left to right; Kw 263, 321, 289, 236. My new ones however have different numbers on. 1041, 1085, 1079, 1106; which order do i put them in from left to right?
Tom
Ht Lead Order
tom1990
, Jan 13 2011 01:29 PM
5 replies to this topic
Posted 13 January 2011 - 01:29 PM
Posted 13 January 2011 - 01:35 PM
The numbering is irrelevant. Take one old one off, put new one on. repeat 3 more times. done.
Posted 13 January 2011 - 01:43 PM
However as acheck.....
No 1 is closest to the radiator, 2, 3 & on to 4 at the other end......
No1 to distributor at 1:00 O'clock position.... unless some one has buit your engine or distributor incorrectly
Posted 13 January 2011 - 03:36 PM
...and then working anti-clockwise around the distibutor the order is cylinder 1, 3, 4 then 2
ie looking at the front of the car the layout should be:
Cylinder Head:
4 3 2 1
Distributor:
3 1
4 2
Cylinder Head:
4 3 2 1
Distributor:
3 1
4 2
Posted 13 January 2011 - 05:21 PM
It could be the different numbers refer to different length leads, Follow all the above advice and fit the lead which looks best in each position.
I actually cut mine to length so wasn't a lot of spare lead flopping around.
Posted 13 January 2011 - 06:54 PM
Cylinder Head:
4 3 2 1
Distributor:
3 1
4 2
Thanks for adding the bits I left off Graeme
