Magnum Classic Mini Panels
Posted 14 January 2011 - 07:59 AM
I've seen the recent thread regarding m machine panels and there quality, has anyone used magnum classic mini panels before? There was a brochure in a recent Mini magazine and they do a go good amount.
Any comments appreciated.
Chris
Posted 14 January 2011 - 09:38 AM
Posted 14 January 2011 - 09:46 AM
I'm under the impression that magnum and hadrian are either linked or similar?
I've pulled stickers off a magnum panel to find a hadrian one underneath and vice versa??!!
It depend what you want to fit.
Posted 14 January 2011 - 10:05 AM
I suppose it also depends on who butchered the car previously (I know the gap between my door and A panel is so big I can put my finger in there! it looks as though its just been bent flat and welded!)
If it doesn't exist I'll offer to try and put one together.
Dan.
Posted 14 January 2011 - 10:14 AM
that could be useful as I need to start buying panels for my mpi which has all original panels still on it, has anyone tried the magnum mpi front panel? they sell for £60 and a heritage one is £150Is there any way of collecting the information to make a chart showing which panels from who seem to be a better fit?
Dan.
Posted 14 January 2011 - 10:27 AM
Wings
Front panel
A-panel
Door steps
Front floor pan/floor repair panels
Door skins(if you don't mind tweaking)
Panels that need to be genuine
Scuttle
Boot lower hinge repair panel
Door skins(for perfect and easy fit)
Rear 1/4(some horrible pattern ones out there and quality is hit and miss)
Thats just a basic list, if you've got a specific panel in mind post it up and see if anyones tried to fit it(and how sucessfull they were!!)
Posted 14 January 2011 - 10:28 AM
Posted 14 January 2011 - 10:30 AM
I've got a pair in the garage ready to go on my car.
Posted 14 January 2011 - 01:40 PM
Matt
Posted 15 January 2011 - 10:37 AM
thanks shifty, thats a few more pounds saved lolI use them and they're fine. The metal is a little thinner but the fit is ok.
Posted 15 January 2011 - 10:45 AM
Just a thought though, my local motor factor offers them cheaper than buying direct from Magnum so have an ask around. They get good trade discount which they pass enough on to be cheaper to the public.
A further question though if someone can confirm or otherwise, the heelboard panels from Magnum are apparently made with metric threaded nuts attached instead of imperial. Has anyone found this to be the case?
Posted 15 January 2011 - 10:51 AM
I have one of these. They originate from x part in desford leicestershire. I chased this issue up and was told that Rover adopted good pattern parts if they are up to spec and put rover stickers over the top.I've had a "genuine" (mmm ebay) boot hinge repair panel and under the rover hologramed sticker was a magnum sticker.
Matt
X part told me that the the stock of these is very old as when X part was set up they inherited a vast quantity from Rover. Not sure how true this is, but if they are good enough for Rover they must be ok?
I was a little peeved that I spent extra money on this panel thinking it was genuine, whereas I could have bought the same panel for a lot less direct from Magnum. Not fitted it yet, so can't comment on the fit.
Edit, the guy at X part told me all the remaining stock was stickered up the same, with a hologram sticker over the Magnum sticker.
Edited by MiniLuke, 15 January 2011 - 10:53 AM.
Posted 15 January 2011 - 12:32 PM
I've also had a battery box from Magnum, never again. Was not level with the boot floor and required some beating.
However, for sills and A Panels they're fine.
Posted 15 January 2011 - 08:34 PM
I fitted a front panel (which did have metric captive nuts by the way so I'd bet on the heelboards also having them).
Front wings
A-panels
Sills
with no problems. Door steps were the only panels that needed replacing that I had bought that just didn't fit. The long folds were nowhere near the originals so I just dropped them and grabbed Hadrian ones instead which were pretty much spot on.
Iain
