Removal Of Rocker Switch Facia
6 replies to this topic
#1 njathind
njathind
  • 447 posts
  • Local Club: Chichester Mini Club
Posted 15 January 2011 - 12:05 PM
Ok, I'm planning on fitting front fogs to my mini and so I have brought all the kit. What I want to know is how do I remove the metal facia plate that holds the rocker switches as I need to replace my 4 hole one with a 5 hole one. I tried the haynes manual but it had nothing an I tride just pulling it out but again nothing.
Any ideas guys and gals?
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 15 January 2011 - 12:33 PM
you need to stick you head in the foot well with your feet on the back seat
look up around the choke/heater cables and undo the lock nut around the cable
the switch panel should then pull off
you will have to disconnect the battery as it's easy to short out the wires in the surround
#3 mab01uk
mab01uk
  • 12,487 posts
Posted 15 January 2011 - 12:45 PM
If you want more access unscrew the 2 front fixing screws for the heater assembly (under the switch panel) and let it drop down a couple of inches.
#4 njathind
njathind
  • 447 posts
Posted 15 January 2011 - 01:09 PM
Thanks I'll give it ago, its at Larry powis's body shop at the mo so no need to worry about shorting as half the stuff is disconected anyways and the battery is out. As its an mpi am I to assume there will only be a lock nut on the heater cable? Or will the choke blanking plug have a locknut aswell?
#5 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 15 January 2011 - 01:15 PM
not worked on a MPI my self so don't know
i'm guessing there must be some sort of fixing on the other side
#6 Mini Cheddars
Mini Cheddars
  • 1,209 posts
Posted 15 January 2011 - 01:16 PM
The choke cable has a nut too but it's a but tight to get to it.
#7 njathind
njathind
  • 447 posts
Posted 15 January 2011 - 01:23 PM
Well i'll have a go and let you all know how I get on with it.
