Edited by HUBBA.HUBBA, 16 January 2011 - 12:11 PM.
Stiff Steering
Posted 16 January 2011 - 12:02 PM
Posted 16 January 2011 - 12:36 PM
Posted 16 January 2011 - 01:05 PM
Posted 16 January 2011 - 01:29 PM
Posted 16 January 2011 - 01:38 PM
Posted 16 January 2011 - 02:10 PM
Posted 16 January 2011 - 06:03 PM
Edited by HUBBA.HUBBA, 16 January 2011 - 06:08 PM.
Posted 16 January 2011 - 06:06 PM
Was it a new rack from a good supplier?
Yes it was from Mini Spares. It's the bushes that's the problem though. As I said earlier, they were really stiff when fitting them to the column out of the car, I couldn't turn the shaft holding the spindle at the top, had to use the steering wheel.
Posted 16 January 2011 - 06:26 PM
Providing the rack you-bolts were lose when the column was re-fitted, they should just loosen up as they bed themselves in.
Posted 16 January 2011 - 06:53 PM
The last mini I replaced the steering bushes on had stiff/tight steering. Although it was to begin with (12x6 wheels and small steering wheel) just the steering column rattled around with the shakes before.
Yep,the you bolts were left loose when the column was fitted. I think the only way might be to take the bushes slightly sand them down on the outside, refit and check. It just seems a bit odd. I didn't push them in too far so they wedge on the rim or anything like that.
Why can't things be simple? They're only basic bushes for @*~# sake!
Posted 16 January 2011 - 07:17 PM
I have no experience with steering column bushes my self so I don't know if they do certain types based upon the age of your car but I have brought parts in the past which people who have minis that are a similiar to mine have had no problems fitting whereas I have had to file them down or cut a bit etc to get the correct fitment.
Trial and error is often the best policy. Try removing them and rubbing them down and then refit them until they feel better
Posted 17 January 2011 - 10:12 PM
Did you grease the column/bushes, it may help if not
Posted 18 January 2011 - 09:17 PM
Changed my column bushes last night, yes they are tight, but are bedding in slowly, and it feels safer to not have the column wobbling about.
Filed them down a bit and now OK. Cheers.
