Rear Light Problem
Minii_Matt
, Jan 17 2011 04:29 PM
9 replies to this topic
Posted 17 January 2011 - 04:29 PM
When my lights are turned on, the right hand rear light constantly has its brake light on (it is brighter than usual, like when braking). The left hand light however is functioning perfectly normally. I have tried changing the bulb, but it made no difference - has anyone got any ideas what may be causing this?
Posted 17 January 2011 - 05:08 PM
so let me get this right
with the lights turned on both tail lights are on and 1 of the brake lights as well ?
with the tail lights off do both brake lights work ok ?
Posted 17 January 2011 - 05:10 PM
sounds like a bad earth
Posted 17 January 2011 - 05:15 PM
Yeah, lights turned on and both tail lights are on and 1 brake light too. When lights turned off, both brake lights work fine.
Posted 17 January 2011 - 05:20 PM
have a look at the bulb holder on the light with both bits lit
other that that dodgy earth's can do funny things
Posted 17 January 2011 - 05:28 PM
sounds stupid, but you have got the bulb in the right way round? It is possible to fit them 180 degrees out, then when your lights are on it's powering the brake light filament.
Posted 17 January 2011 - 05:38 PM
Thanks, I'll look into all those things! Hopefully the bulb is in the right way round, that would be embarassing! If they fail, I'll track the wires back and look for a dodgy earth. Thanks!
Posted 18 January 2011 - 08:07 PM
Did you get it sorted mate?
Posted 20 January 2011 - 04:23 PM
Yeah thanks. As embarassing as it sounds, it was just as you suggested - the bulb was fitted 180o out! Thanks for the replies!
Posted 20 January 2011 - 06:17 PM
Glad you got it sorted.
