Temp Sender - In Sandwich Plate M12 X1.5 Thread
Posted 19 January 2011 - 06:44 PM
Ive got a non MPI mini running a MPI front rad set-up i bought off a mate, im improving the set-up as the rad/fan switch was in a hose take off on the bottom hose where it should have been running from the top hose where the hot water is.
Im trying to find a repalcement sender/swtich to replace the brown one in the sandwich plate as its a variable sender which tells the ECU whats going on, what im after is a replacement switch which has a 12x1.5mm thread and works in the right temp region 95-90degrees
Has anyone else done this or knows of a suitable item?
Gaz
Posted 19 January 2011 - 07:07 PM
As far as i can see there are 5 different coloured sensors, brown, black, green, blue and white. Get along to your local parts place and they'll be able to source the right oneHi all
Gaz
Posted 20 January 2011 - 09:59 AM
Posted 20 January 2011 - 10:13 AM
http://www.lucaselec...8_technical.pdf
Posted 20 January 2011 - 12:34 PM
Hi all
Ive got a non MPI mini running a MPI front rad set-up ...................................
Gaz
I think we need to know a bit more information. Are you running an injection setup or are you running carbs ??.
Are you trying to feed an ECU or are you just trying to switch on the fan ??
Posted 20 January 2011 - 07:34 PM
Im just trying to switch the fan automatically as i have a manual bypass switch, what im trying to do is tidy up the coversion by utiising the sensor placement which has the brown coloured temp sender.
All im after is a replacement fan switch with a M12x1.5 Thread , should be easy you would think?
I could use my current Temp switch
Posted 21 January 2011 - 04:06 PM
No its a carb'd MG1275 engine which has a MPI rad set-up, with custom brackets to mount the alternator.
Yes I suspected that's what your set up was. In your inital post you mentioned the switch was in a take off on the bottom hose. Now you say it's a manual switch, so I'm a bit confused.
All I can tell you is that the SPI and late model 1275 carb's had a sender in the bottom of the radiator to switch the auxillary fan on. This works fine so I don't see why a take off from the bottom hose should be any different.
Might be a bit of an overkill but one of these would do the job.
e-bay link fan switch
You may also get more advice if you post this in the general Problems, Questions and Technical section as theres more going on there and it's not a specific injection answer your looking for
Posted 22 January 2011 - 06:32 PM
The SPIs work fine but the MPI rad is much more efficient than the side mounted variants so having the temp switch in the bottom hose means by the time it has got hot enough the engine is cooking itself
Will get a photo up when ive changed the HG and stuck it all back together!
