Building A Shorty
4 replies to this topic
#1 canadiankev
canadiankev
  • 30 posts
Posted 20 January 2011 - 08:11 AM
Hi i'm seriously thinking on building a mini shorty out of the project car i have but just not totally sure where to start is there anywhere a person can find out the steps to take to build a shorty? All help would be apperciatedAttached File  78_mini_002.jpg   847.92K   7 downloads
#2 charie t
charie t
  • 3,153 posts
Posted 20 January 2011 - 11:00 AM
This is not a small project, if you have never tried welding before get a welding course booked because the welding required in this is crutial to the structure.
This is only how i would do it but definately not an official guide.
Add some decent, well attatched bracing, box section is easiest. Decide how much you want to shorten it. Mark how much you are shortening it on the box.
Decide where you want to cut it, through the door step is what is done most as there is the quarter panel to fill up the door gap.
Chop off the roof
Cut it all the way through and cut out the shortened length from the floor body and the box then match the 2 halfs together, the box should then line up square with each other and the body will still be in line. weld it all up and fill all the gaps that are left (depending how short you have gone with it)
The body will need to have some strengthening as the roof will be gone
#3 Ethel
  • 26,073 posts
Posted 20 January 2011 - 11:30 AM
Don't forget your IVA (Sorry Bungle, beat you to it)
I'd shorten the floor pan from the back so you can reattach the heel board without adding any extra joins. Detach the side panels so you can stagger the joints.
#4 charie t
charie t
  • 3,153 posts
Posted 20 January 2011 - 12:04 PM
its not been mentioned about putting it on the road, and canadiankev suggests to me he might be in canada
#5 998dave
998dave
    998cc's Of Dave Goodness
  • 4,566 posts
  • Name: Dave
Posted 20 January 2011 - 12:15 PM
I think it's fair to assume it's likely to be planned for road use, and better to have the warning in there then not.
I think he's in the UK...
Other Information
Back to the subject, you'll probably find theres a thread or two in the projects section where people have made shorty's, so may be a good place to look...
Dave
