Diesel Fiesta Fuel Consumption Isnt Right
Posted 20 January 2011 - 07:36 PM
Seeing as i only work on classic cars and have never really touched a modern car, has anyone got any ideas what could be wrong, or is it a case of take it for main dealer for a diagnostics and spend lots of money? Thanks again tmf!
Posted 20 January 2011 - 07:53 PM
me old dears got a 56 plate fiesta tdci, when we first bought the car about 6 months ago, fuel consumption was very good, average of about 65mpg, but over the past few weeks it seems to be using a lot more fuel, we filled it up from when the light come on, 45 litres, the cars done about 300 miles of mixed driving. Which works out to be about 35mpg, which i think is pretty rubbish, considering the 65mpg we were getting when we first bought it.
Where are you buying your diesel from?? i used to get mine from Tesco's as it was cheap with the old vouchers, however my consumption was poor. Instead of high 40's early 50's i was getting high 30's early 40's. Not happy considering i do over 540 miles per week.
Went back to Morrisons and bingo fuel consumption was back to normal. I went the diagnostics route, no fault found, tyre pressures, had my driving style changed etc but no all was as per normal it was just down to the fuel.
Has your car been serviced regularly?? do get a fault code read it may show something. The MAF is always a prime suspect on turbo diesel motors. Have you noticed a loss in power?
My car is not a Ford but a VW Passat but the components are the same. It could be a small air/vaccum pipe has become disconnected etc.
Does it chuck out more smoke than normal. The list goes on and on i'm afraid.
You could try joining a Ford forum for festers and see if they can through any light on your problem.
Posted 20 January 2011 - 07:55 PM
normally a good service gives you alot back
Posted 20 January 2011 - 08:02 PM
Urm, it does hesitate a bit when pulling away if you dont slip the clutch, but i kind of guessed its turbolag? Me mum said it messed around the other day when she was pulling onto a roundabout, hesitated for a few seconds with virtually no power.
Posted 20 January 2011 - 08:05 PM
check the piping if your having turbo hesitation too, might be leaking boost
Edited by mini93, 20 January 2011 - 08:05 PM.
Posted 20 January 2011 - 08:07 PM
Oil
Oil filter
Fuel Filter
Air Filter
then i flush engine injector cleaner through
just to make sure i get it all clean
but alot of fuel lately is proper crap and what it says on ur Fuel cap is RUBBISH! use what fuel you think and like, they put that on so they get money from it only reason big fuel companys pay to get it put on there cars! just one big scam
if i remeber rightly if it is the Endura engine they like messing EGR valves up aswell! like to make them stick on a bit so it under powers the car!
Edited by Stevee, 20 January 2011 - 08:09 PM.
Posted 20 January 2011 - 08:11 PM
any odd noises coming from the car recently, cyclonic turbo noises etc have a look if you can block off the EGR valve.
problem is, the damn things so quiet inside, i can hardly hear the engine. Whats an egr valve? Ill have a look over what piping i can see tommorow, thanks.
Posted 20 January 2011 - 08:13 PM
well, it says on the filler cap, that ford reccomends using bp fuel, so we only use bp fuel in it. As for servicing goes, i doe an oil and filter change 3,000 miles ago, and changed the air filter, couldnt think of anything else to change. Tyre pressures are done every fortnight.
Mmm should be no need to slip the clutch, its not turbo lag, the lack of power on the roundabout means there is a problem. Take it to a garage and get a diagnostic done. It could be the MAF or the EGR or something else. Unfortunately with modern diesels they like everything to run right so if a sensor is down it will make a huge difference. You do not have to take it to a main Ford dealer, any decent garage will have the facility to fault code read.
Posted 20 January 2011 - 08:15 PM
on the air intake pipe theres a Air Flow Senor these on fords love to brake! they mess everything up make it all under powered!
i know this cause ive just done my mums one on her car cause it had no power now its all back!
Posted 20 January 2011 - 08:23 PM
And by MAF, i guess you mean mass air flow sensor? I hate modern cars, lol, i done my apprenticeship on classic cars, hence why im kind of lost here.
Posted 20 January 2011 - 08:26 PM
soo any ideas how much ill be looking at for diagnostic?
Yes the mass air flow sensor or what i said. they normally go clog up with oil from the turbo and then burn out
new one be about £50ish depends where you go but im 90% sure its this
Posted 20 January 2011 - 08:30 PM
