Offset Confusion
6 replies to this topic
#1 Artful Dodger
Artful Dodger
    " I AM THE SPECIAL ONE"
  • 4,435 posts
Posted 21 January 2011 - 08:20 PM
the wheels i want have what is called offset ET-7. what does this mean???? i need to know the size so i can do measurements without buying the wheels......anyone know what this means??? thanks
#2 akaflash
akaflash
  • 96 posts
Posted 21 January 2011 - 08:47 PM
the ofset is where the hub mounting face is relative to the centre of the wheel rim, 0 ofset would put the mounting face in the middle of the wheel, yours at et -7 would put the wheel centre 7 mm in of the centre making these wheels stick out a long way, would need big arches
#3 mini13
mini13
  • 3,811 posts
Posted 21 January 2011 - 10:36 PM
you say "in by 7mm", its actually out by 7mm,
for example if you have wheels with 0 offset and you change them for wheels of -7 of set it is the same as adding a 7mm wheel spacer.
just by the mention of -7 offset I presume you are looking at 7x13 rims, as a comparison the spots pack rims are 6x13 with +21 offset, offset wise that's the equivalent of a 28mm spacer.
#4 akaflash
akaflash
  • 96 posts
Posted 21 January 2011 - 10:48 PM
i know thats why i said moves the wheel centre in.
#5 timmo
timmo
  • 156 posts
Posted 22 January 2011 - 08:46 AM
This may help explain........ https://www.rsracing...tech-wheel.html
but may confuse you even more LOL
#6 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 22 January 2011 - 09:13 AM
Or maybe look in the FAQ's......
http://www.theminifo...?showtopic=6750
#7 Artful Dodger
Artful Dodger
  • 4,435 posts
Posted 23 January 2011 - 07:10 PM
Thanks everyone :D this has helped me no end as i have bought arches knowing they will fit >_< cheers
