Whitey / Bluey Smoke
Posted 21 January 2011 - 09:57 PM
i have noticed recently there is a lot of whitey / bluey smoke coming out of my exhaust. is this normal? i was thinking it is just because the weather is cold at the moment but just thought id check to be on the safe side
cheers
sean
Posted 21 January 2011 - 09:59 PM
Posted 21 January 2011 - 10:00 PM
Posted 21 January 2011 - 10:01 PM
As said blue is oil and white could just be moisture etc.
Posted 21 January 2011 - 10:03 PM
As mentioned check your fluid levels and carry out a compression check to be safe. White coloured smoke is normally water based, blue is oil, grey/black fuel.
Posted 21 January 2011 - 10:04 PM
Posted 21 January 2011 - 10:05 PM
the smoke is white mainly with a very slight blue tint
So its water based (white) , mixed with oil (blue)
Posted 21 January 2011 - 10:07 PM
Posted 21 January 2011 - 10:10 PM
Edited by glyn, 21 January 2011 - 10:10 PM.
Posted 21 January 2011 - 10:36 PM
Have a look at your oil cap on your rocker cover, if there is a white gundge instead of oil it probably is head gasket (water getting into your oil ). Also have a look at the radiator cap for any sign of oil.
Edited by HUBBA.HUBBA, 21 January 2011 - 10:37 PM.
Posted 22 January 2011 - 01:01 AM
if it is only just going can i change it myself or do i have to get a garage to do it so the head gets skimmed?
cheers
Posted 22 January 2011 - 01:53 AM
its not a bad job to do yourself depending how mechanically capable you are, and any machinist company should do a head skim, my local did it for £40. the head doesnt have to be skimmed if your car hasnt overheated massivly as it may not have warped, but is better to do so, so is upto you depending on time/cost etcc
Posted 22 January 2011 - 05:29 PM
