Hole In Heater Matrix
4 replies to this topic
#1 087dave
087dave
  • 952 posts
Posted 22 January 2011 - 04:03 PM
Hi all, i have taken out my heater matrix because of a leak in the car
i found a small pin hole in one of the tubes at the side, so i would like to try a repair but the thing is
what type of material is it ,
can it be brazed are is there a another way,
Thanks very much.....
#2 bmcecosse
bmcecosse
  • 9,699 posts
Posted 22 January 2011 - 04:49 PM
Try soldering it!
#3 087dave
087dave
  • 952 posts
Posted 22 January 2011 - 07:35 PM
[quote name='bmcecosse' date='Jan 22 2011, 04:49 PM' post='2030525']
Try soldering
Thanks do you mean silver solder as in you feed in a rod with heat
cherrs
#4 andydclements
andydclements
  • 104 posts
Posted 23 January 2011 - 03:34 PM
Silver solder is a specific blend of solder, which has a hotter melting point then most types. Use normal solder, in some respects the cooler the melting point the better as you don't risk disturbing the existing solder joints as much.
Yes to the rod and heat method. Pinch up the core that is holed so that when you solder it up lots of the solder doesn't just flow into the heater matrix. You need to clean the area with wire wool as much as practical , make sure it's dry inside and out then use a flux (paste is better than liquid). A fine pencil type gas torch is best for this, heat the area and feed the solder in to plug the hole.
Andy
#5 1984mini25
1984mini25
  • 8,787 posts
Posted 23 January 2011 - 03:42 PM
I repaired one of mine with chemical metal, only a few weeks later it just found somewhere else less assessable to pee from instead.
