Model: 1275 Mini Sprite
Year: 1994
Hi - I had to change my rod eye socket, the part that the bottom ball of the gear lever sits in to control the rod selector, since this had worn. I removed the whole gear lever housing, steady bar and selector shaft. Tried to punch out the roll pins holding the rod eye to the selector shaft but the rod eye snapped - so bought a second hand gear lever housing which came with the selector shaft, rod eye and steady bar. It did not come with the rod change eye bolt sleeve coupling which is used to attach the selector shaft to the gearbox housing but I just took it off my old one and added it to the new one.
I have put the gear lever housing in place, tightened the steady bar etc. but notice that neutral position is too far back in the cabin and hence the rod eye is too far forward in the gearbox housing which does not allow me to select 2nd or 4th. I cannot figure out where I have gone wrong but think it is something to do with the selector shaft position. The coupling seems to be symmetrical so putting it in the wrong way is not possible (i think). I have screwed the reverse switch far out to minimise this being a problem to selecting gears.
Anyone have any ideas where I might have just gone wrong?
Any non-standard parts that might be involved with the problem? No
