Alternator Or Generator
Posted 24 January 2011 - 06:52 AM
Please give your topic a title that quickly describes your problem. Just putting 'Help my Mini doesn't work' is useless to anyone trying to help.
Model: Austin Mini
Year: 1989
Description of problem (please be as in depth as possible): How do I tell if I have an alternator or generator? Whichever it is, it has three wires going to a flat plastic "plug" that is held on by a wire retainer. The wires going into the plug are iffy at best and causing charging issues, I believe. I've tried to repair it twice, and works for a while. Is this plug and the metal connectors in it available anywhere? The red light on the speedometer is glowing just slightly (is this the charging indicator)? If I do have a generator, where is the voltage regulator located?
Posted 24 January 2011 - 07:35 AM
you have an alternator red light is charge the light put a meter on the battrey with the engine running it should read 14 volts~~~~~Please delete this text before posting the topic~~~~~~
Model: Austin Mini
Year: 1989
Posted 24 January 2011 - 07:40 AM
