Turbo Chargers
14 replies to this topic
#1 Gdowle
Gdowle
  • 55 posts
Posted 24 January 2011 - 04:27 PM
Hello,
I'm looking for a T2 turbo charger from a Renault 5 gt and having difficulty finding one online. I live in Canada now and Renault is not sold here. T2's are on some American cars. What would I have to change on the turbo to make it fit a mirage manifold? Or am I going to have to replace the whole housing? Thanks
#2 boffster
boffster
  • 151 posts
Posted 24 January 2011 - 04:48 PM
Hello,
Hello,
This May Help :) . May be wrong, but i think that the T2 and T3 mount the same?? Hope this helps
#3 jamie@thefatgarage
jamie@thefatgarage
  • 120 posts
Posted 24 January 2011 - 05:18 PM
Hello,
Hello,
T2 and T3 are different flanges/hole centres. You can buy flanges on ebay. Just cut off the wrong one and weld on whatever you need. Or build a manifold. Its not difficult if you have reasonable fab skills and costs a LOT less than £350 for a mirage one.
#4 Liam Mini 35
Liam Mini 35
  • 412 posts
  • Local Club: sheffield mini club
Posted 24 January 2011 - 05:19 PM
have a look on www.turbo-mini.co.uk
#5 Gdowle
Gdowle
  • 55 posts
Posted 24 January 2011 - 06:08 PM
sorry what i meant was, if i bought a T2 used from another vehicle (pontiac sunbird GT). I think the design is different than a Renault 5 GT. or am i wrong and the T2's are all the same design and fitting. What would i need to make a T2 the same design as R5 gt?
Im rubbish at welding and the mirage seems to be the easy way to get a good guaranteed fit. Maybe once i get to the manifold stage i will give it a go.
thanks
#6 mini13
mini13
  • 3,811 posts
Posted 24 January 2011 - 06:17 PM
you should be able to find something,
as an example the GT17 from the saab95 is a vary good turbo, they are a bit tricky to get here in good condition but you may have more luck the other side of the pond.
#7 jamie@thefatgarage
jamie@thefatgarage
  • 120 posts
Posted 24 January 2011 - 06:18 PM
There are variants of T2 with different specifications and exhaust exit fittings, you would need to research the Garrett part number of any you find to see what spec it is and how it compares with the R5 unit. Google the part number and you can usually find info.
#8 Wil_h
Wil_h
  • 3,244 posts
Posted 24 January 2011 - 07:13 PM
The spec of the T2 on the R5 was fitted to a number of european car, but not sure they ever made it to canada. Similar spec turbos are available. For instance:
Garett GT1548 - may be fitted to cars over there, you don't wanmt the VNT one though.
IHI RHF4 - this is what I have on my mini, was fitted to a few cars such as Subaru Legacys, mine came off a digger
There are others but they don't spring to mind.
#9 samsfern
samsfern
  • 5,243 posts
Posted 24 January 2011 - 07:21 PM
ive been looking for a renault 5 turbo for a few weeks now, and havent found one, i think the fiat uno turbo had the same turbo fitted.
#10 Gdowle
Gdowle
  • 55 posts
Posted 24 January 2011 - 09:22 PM
yea i want to just bolt it on really. rather than doing too much fabrication. as far as i know i should just have to modify the actuator bracket on the t2 r5 turbo. is there a particular year or part number it has to be to fit the mirage manifold?
#11 Gdowle
Gdowle
  • 55 posts
Posted 24 January 2011 - 09:33 PM
can anyone confirm if this is from a R5 GT Turbo and will fit mirage manifolds?
http://cgi.ebay.co.u...62#ht_500wt_951
#12 Wil_h
Wil_h
  • 3,244 posts
Posted 24 January 2011 - 09:47 PM
That's not an R5. R5s have 4-bolt flanges, that has a 3-bolt. It's a GT15 I think.
#13 Gdowle
Gdowle
  • 55 posts
Posted 24 January 2011 - 09:55 PM
thanks mate.
#14 rick.spi
rick.spi
  • 1,686 posts
  • Local Club: "WOT NO BRAKES"
Posted 25 January 2011 - 01:01 AM
tis always worth searching for a more modern turbo first as mentioned above, as if you need to work/ fab stuff to put it all on its no more efford using a better more modern efficient turbo, im using a gt2056 (not reccomended for smaller bored engines) but theres the gt15 and 17 and the above mentioned ones.
#15 Jacko-lah
Jacko-lah
  • 507 posts
  • Local Club: Derbyshire Classic Mini OC
Posted 25 January 2011 - 10:34 PM
Some 11 years ago I worked for garrett (Honeywell Engine Boosting Systems) in Skelmersdale as a New Product Introduction Manufacturing Engineer. I only worked on Variable Nozzle Turbo's for Diesel, but correct me if I'm wrong but the NUMBER is just the size of the shaft, and there are many 1000's of specific applications, with many variations from inlet and outlet fittings, to the size and shape of the wheels, but I think this might help
http://www.honeywell...EF663C333D8.htm
http://www.honeywell...C8-74B54C4A5004
http://www.honeywellbooster.com/
United Kingdom
BTN Turbo Ltd.
Master Distributor
Arundel Road
Uxbridge Trading Estate
UXBRIDGE
UB8 2RP
Tel: + 44(0) 1895 466666
Fax: + 44(0) 1895 466667
www.btnturbo.com
Owen Developments (UK) Limited
28 Kingston Business Park
Kingston Bagpuize
Oxford
OX13 5AS
Tel: + 44 01865 821062
Fax: + 44 01865 821076
[email protected]
www.owendevelopments.co.uk
