Boot Security
Posted 24 January 2011 - 04:32 PM
Posted 24 January 2011 - 04:36 PM
Failing that have you considered an internal boot release? Not a particularly easy mod but possible. Of course if the b4stards who did it had morals then it wouldn't be a problem, but unfortunately we have plenty of scum bags to watch out for in the world
Posted 24 January 2011 - 04:59 PM
Tried fitting the standard battery clamps and locking these down (Drill hole through the studs and bend pins or wire around the threads a few times)?
I sympathise with you as my boot used to get broken into all the time, I moved house in the end. You could sit in another car for a few night and try to catch them in the act?
Posted 24 January 2011 - 05:31 PM
Posted 24 January 2011 - 05:35 PM
Edited by olds_kool_lews, 24 January 2011 - 05:35 PM.
Posted 24 January 2011 - 05:51 PM
Please try this I'd love to see the result!
You could also wire it in series with a flashing beacon in the boot so everyone could see them in the dark street!
Posted 24 January 2011 - 05:53 PM
I have a hole in my parcel shelf to allow air movement from my sub. And with the hole, and the boot closed, theres a gap next to the catch in the boot handle, where the catch folds down to open the boot if you get what im on about.
A piece of strong steel, or a bolt pushed in, will stop them from opening the boot completely, even if the lock gets drilled.
A) you cant turn the handle, because there is nowhere for the catch to go
B) strengthens the catch itself if they try to yank it open, as theres extra metal poking upwards.
Of course, the only way you could do this, is by cutting a hole out so that you can get your hand through. Suitable sized hole saw and some flexible seam trim will stop you cutting yourself. Then simply place the parcel shelf cover back over, and they'll never know
Or theres the easy option if its availible. Park the car with the boot up against a wall or garage door so that they cant get to it in the first place.
Edited by Carlzilla, 24 January 2011 - 05:56 PM.
Posted 24 January 2011 - 06:42 PM
hope that helps
YetI
Posted 24 January 2011 - 07:02 PM
curl up in the boot for a few hours 1 night, when they break in, unfold yourself and chase after them once the cramp has subsided lol
Posted 25 January 2011 - 12:03 AM
You could fit a better bar that bolts directly through the boot floor, and use two nuts locked together so it's hard for them to get off.
Then fit an alarm with the boot on the door trigger circuit. Parking close to a wall or other car is a good idea if you can.
Edited by mini_mad69, 25 January 2011 - 12:06 AM.
Posted 25 January 2011 - 11:21 AM
Thanks both, think I might have to go with an alarm despite the cost, not sure i'd feel comfortable shocking people through the handle lol
the cheapest way around this i think is to run a wire on a pin switch from the horn to the boot.so when the boot is open your horn will go of making them run away i think.
Posted 25 January 2011 - 11:34 AM
Buy a double air motor air horn.. - £11
Fix it in the boot.
Wire it up to the battery..
Just connect the wire to the boot..
So when it opens and breaks the Circuit Anyone in that area will know about it
Trust me
Posted 25 January 2011 - 11:50 AM
Plan B - fill the boot with wasps.
Posted 25 January 2011 - 12:40 PM
lol
Not much you can do though if someone wants to break into the fortress otherwise known as a Mini. Best bet's just to leave it unlocked to minimise damage
Posted 25 January 2011 - 12:59 PM
Cheapest option i know because i have done this
Fix it in the boot.
Trust me
Exactly!
lol
I agree- if empty and all doors rigged to a horn leave it unlocked to save damage! Just fit a secret dis-alarm switch somewhere so it doesn't go off when you get in!
