Peugoet 207 Oil Change
4 replies to this topic
#1 SKIDDERWOLF
SKIDDERWOLF
  • 315 posts
Posted 24 January 2011 - 08:10 PM
Anyone done a oil change on a peugeot 207 1.4 Vti? Do these cars have sump plugs or do I need to suck the oil out from the dipstick hole?
#2 xBR4DLEY
xBR4DLEY
    >>mine's still gay<<
  • 1,618 posts
Posted 24 January 2011 - 08:13 PM
Used to have one of those with that engine , 90bhp DOHC Vti ftw
Now we have the 75bhp SOHC piece of *******
and I'm guessing probably sump plug mate , I would jump under and check if you want but we got a different engine to you ......
#3 xBR4DLEY
xBR4DLEY
    >>mine's still gay<<
  • 1,618 posts
Posted 24 January 2011 - 08:28 PM
Just read this and apparently its to be sucked out :/ Weird.
#4 valve bounce
valve bounce
  • 694 posts
Posted 24 January 2011 - 08:56 PM
i work on these day in day out, just to make sure it is a 1.4 16valve model? is so it will have a sump bung which will be a, 21mm socket, 8mm allen key or a sqaure drive (gotten the size). the oil filter is visable from the top and on the gearbox end of the engine (27mm socket 6inch extension 1/2 inch ratchet) do not overtighten as they can crack. as for oil, 5w30 synthetic and dependant on the size of the sump it will either be 3.3 or 3.5 liters of oil.
hope this helps rob
#5 SKIDDERWOLF
SKIDDERWOLF
  • 315 posts
Posted 15 March 2011 - 07:51 PM
Thanks for the replys , Time for an oil change :(
