Recaro Seats
5 replies to this topic
#1 lapider
lapider
  • 473 posts
  • Local Club: cardiff mini club
Posted 24 January 2011 - 09:34 PM
i was thinking of fitting a set of second hand recaros in my 87 mayfair i have a few things im unsure of however
1 would they fit with sufficient head room
2 i was planning on making my own subframes that use all the original mounting points seats and make the subframes to fit them would that suffice
3 i was planning on using the original seatbelt and mounts would that have problems
#2 L400RAS
L400RAS
  • 2,479 posts
  • Local Club: Lincolnshire Mini Owners Club
Posted 24 January 2011 - 10:32 PM
What car are the Recaros originally from?
I have Ford Escot XR3i (turbo) in mine. I had to first grind off the original ford fitting brackets, leaving the horizontal runners
I fitted two L shape brackets to the box section that come up the face and go rearwards, about 1" rear of the box section (4mm steel). I then drilled a single mounting hole in the last inch or so for the front of the runners.
For the rears, i made up two "feet", of hte same height as the box section so the seat was level (almost - tilts slightly back). The foot nearest the tunnel had to have a plate projecting towards the handbrake, as the foot does not sit level on the floor. This foot used one of the original seat "hook" holes, with a piece of 3mm scrap steel underneath as a force spreader. The other foot I did drill a new hole in the floor, but to be honest I probably didnt have to fix the outer side down. Repeat for the other seat. Sorry, I cannot get photographs as I am storing that car at my grans for winder... i'm sad, I know...
#3 lapider
lapider
  • 473 posts
Posted 25 January 2011 - 01:13 PM
i was thinking of getting them from a mk 1 golf or other golf
could i just unbolt the existing frames fom the seat or would they need to be ground off
#4 turbominij
turbominij
  • 29 posts
Posted 25 January 2011 - 01:46 PM
i used rs turbo ones and used the cobra subframes with adapterplates to make the holes line up
#5 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 25 January 2011 - 02:27 PM
1 yup loads of room.
2 Yup they'd be fine as long as they are strong enough
3 yup again should be fine
I have RS2000 mk5 seats in mine, and I just bolted the seats down with some L shaped brackets on the seat and L shaped brakets on the floor of the car.
I don't have runners.
You can kinda of see one of the mounts there.
Theres just a picture of the seats so you can get an idea. Im using harness but a standard belt should work no problem.
#6 lapider
lapider
  • 473 posts
Posted 26 January 2011 - 09:49 AM
thanks for that guys thats realy helpful
