The pedal has always had a bit of movement at the top where it actually does nothing, this is now clearly because the hole in the pedal is larger than the clevis pin, is it the hole in the pedal thats worn larger or is this pin meant to be straight across and mine is severly worn in the middle?
Next I moved onto the brake pedal, the haynes book of lies says this should be the same as the clutch pedal. But in the picture below you can just about see (hopefully!) that there isnt a split pin and clevis pin but some sort of other what looks like immovable pin!! How are you meant to remove this? Or Am I missing something stupidly obvious
Any help would be much appreciated, I need to get the car back on the road ASAP as I normally use it for my near 40 mile daily commute and my mates Vauxhall Corsa isn't doing my reputation any good!
