Acceleration Problems Takes Time To Bulid Up To A Hi Rev
4 replies to this topic
#1 minilee94
minilee94
  • 3,523 posts
Posted 25 January 2011 - 07:20 PM
hi i have got a 1991 mini city e auto
998cc standard hs4 cu carb
i brought the car from a guy not to long ago it had been sitting up his drive for about a year and when you try and rev the car up it takes abit of time to build up to a hi rev and while im trying to rev it up it sounds like its popping not popping in they way of back fire just apopping noise from the exhaust and when you do get to a serton rev its okay
also when the car is warmed up it runs abit better Does it just need a good tune up or is there something wrong opinions please
thank you
lee
#2 wassupcrew
wassupcrew
  • 502 posts
Posted 25 January 2011 - 07:26 PM
sounds like it needs a good tune. if its been sitting for that long i would start by changing the plugs points and condensor, it its got them, and then check the timing
#3 minilee94
minilee94
  • 3,523 posts
Posted 25 January 2011 - 07:28 PM
oh rite okay thank you im in the middle of buying some new HT leads got points already and getting new plugs aswell so il see what happen lol
#4 bmcecosse
bmcecosse
  • 9,699 posts
Posted 25 January 2011 - 07:31 PM
Look to the air filter -and does the piston in the carb rise easily and fall back with a nice clunk? Also put 3 in 1 in the carb damper. Then check the vacuum advance is connected and working as it should. Suck the pipe and watch to see the dizzy baseplate move - and retract.
#5 Minihaha
Minihaha
  • 29 posts
  • Local Club: n/a
Posted 25 January 2011 - 07:58 PM
thank you
lee
If the car has the same petrol in for a year the petrol can break down and not burn correctly, you could drain it off and put fresh in, or even a drop of octane booster for a better ignition burn, if things do get better you'll know it could be fuel problem, also the float chamber dries up when a car stands a long time, this causes the needle valve in the chamber to stick or partly stick,which could starve your engine, Good luck
