Metro Timing Cover Breather
4 replies to this topic
#1 mini670
mini670
  • 293 posts
Posted 26 January 2011 - 10:19 PM
Wondering about my metro engine timing cover breather to fan clearance. Searching only came up with 3 hits for what im looking for.
It seems people hammer the breather in slightly to gain the clearance, but sure that I have seen a post somewhere that shows the breather chopped and re-welded?
My question is, does it the breather contain anything? Not sure but seem to remember seeing a coarse foam on some photo somewhere??? If so would it matter leaving this out as it would melt on re-assembly.
Should it be brazed or welded?
Ta
#2 bmcecosse
bmcecosse
  • 9,699 posts
Posted 26 January 2011 - 10:22 PM
You can do either - only a wire mesh inside. If you bash it flat - take care you don't bash the cover into the timing chain and/or the sprockets.
#3 mini670
mini670
  • 293 posts
Posted 26 January 2011 - 10:37 PM
Cheers,
Cover is off, as im rebuilding, and fitting duplex. Might have a go at chopping the breather then if its a wire mesh.
Do you know of messing about mig welding it would cause distortion, and increase the oil leaks?
#4 Joe555
Joe555
  • 240 posts
Posted 27 January 2011 - 10:49 AM
Do you need to do anything? when I put a Metro engine in my Mini City all I did was put a spacer on the water pump and the fan was clear of the breather and the radiator, its worth checking to save you hanmmering or welding.
Joe
#5 AndyMiniMad.
AndyMiniMad.
  • 3,295 posts
Posted 27 January 2011 - 12:04 PM
I cut and welded mine. here are the pics.
Hope this helps.
Sorry wrong code input on first attempt
Edited by AndyMiniMad., 27 January 2011 - 12:14 PM.
