Home Soda Blasting
Posted 28 January 2011 - 10:11 AM
Posted 28 January 2011 - 11:51 AM
I then decided to give it a try, but with a sweet twist!!
Have a look here at the results.
My Sweetener!
I just used a normal cheapy (from one of those Halfrauds air tool kits) shot blaster!
Came out rather well!
Posted 28 January 2011 - 12:03 PM
NOTE: As far as air compressors are concerned for blasting, the bigger then better. The more CFM it flows the better the results will be. If you try and blast with a tiny 2 gallon compressor, you will be disappointed. For best results use a compressor with at least a 25 gallon tank that flows at least 6 - 7 CFM. I personally use a 60 gallon, 5hp, upright, Ingersol Rand and get fantastic results. Again, the bigger compressor the better.
That's the bitter pill....
You WILL need a decent compressor, and if you can afford one of those, why not just purchase a blasting cabinet aswell...
Even taking the american gallon (7 pints) instead of the imperial gallon, you're looking @ a 100ltr 3hp compressor before I'd even consider blasting with it..
Posted 28 January 2011 - 05:09 PM
