Fuel Tank/ Mot Enquiry
Posted 28 January 2011 - 03:51 PM
http://www.sm-engine...y_fuel_tank.php
but that would obviously mean the breather and filler will be in the boot is there anything i need to do to get it passed an mot/ make it legal for road use cheers
Posted 28 January 2011 - 04:21 PM
There are a few things which you MUST do:
1. Fully seal the interior of the car from the boot with a fireproof material. This must include each side of the vertical rear seat back, the ends of the rear shelf and blanking off any speaker holes or other openings in the rear shelf.
2. Run the breather pipes to the outside of the boot, coming out under the boot floor and using top quality pipe, such as 1/4" fuel pipe marked as such.
3. Blank off the existing filler cap hole with a very large rubber grommet.
I hope this helps. The only other thing is, where will you put the spare wheel?
Posted 28 January 2011 - 07:06 PM
Just because your car can pass the MOT it does not mean it is safe or legal and you should do all the things Cooperman has suggested in his post.
Posted 28 January 2011 - 07:13 PM
Posted 29 January 2011 - 02:34 AM
the frequant stops for fuel did you check out the link i posted its an 11 gallon tank bigger than a standard mini tank so there would be less frequant stops for fuelI know its your car but why would you want to do this on a road going car, my mate did this many years ago with his and soon got peed off with the constant stops for petrol and soon the novelty wore off
Posted 29 January 2011 - 02:38 AM
thanks for that cooperman. do you know of any fireproof material to use? and as for the spare wheel i have never had a spare wheel in any of my minis but i am going to be mounting it on a cage so a spare wheel could be fitted underneath that if i decide to get one when the car is finished.They are good for competition Cars which have to conform to stringent safety requirements, so on a road car they would be excellent.
from what you are saying basically i should be running a breather pipe that comes out of the boot floor? would it be wise to put a little loop in the pipe as to stop any liquid getting out of it aswell? as for the old filler whole i will be welding it up as if i decide to go back to it in the future it can just be re drilled again so is no real problem cheers
Posted 29 January 2011 - 06:56 PM
from what you are saying basically i should be running a breather pipe that comes out of the boot floor? would it be wise to put a little loop in the pipe as to stop any liquid getting out of it aswell? as for the old filler whole i will be welding it up as if i decide to go back to it in the future it can just be re drilled again so is no real problem cheers![]()
What I've always is P38 glass fibre 'hole-bridge. That's the stuff with the fibres in the mix and it goes off really hard and strong. Now, someone is going to say that it's flammable, but it will keep the fumes out of the interior and is accepted by motor sport scrutineers.
You need to mount the new tank as low as possible in the boot to keep the roll-centre as low as possible and thus avoid 'roll-oversteer' when cornering hard with a full tank - remember, 11 gallons of petrol weighs around 110 lbs, that's 55 kg.
With regard to the vent pipe, run it upwards before going out and that will be fine. It must vent outside the boot area and be clipped back to the car structure. There must be no risk of it being damaged or split.
11 gallons gives a really good range and is what the cars with twin tanks have in total.
That sounds like a really good project so long as you don't need alot of boot space. I've seen comp Minis with such tanks and with the rear seats removed and the spare clamped onto the vertical seat back panel inside the car - just a thought.
Posted 29 January 2011 - 07:28 PM
Like this pair of beauties from auto-bmc.com currently on the Monte Carlo Historique - they started from Glasgow.
And I have no idea why the picture appears 'brown' - the cars and the Service Barge are of course in the correct Flame Red
Edited by bmcecosse, 29 January 2011 - 07:40 PM.
Posted 29 January 2011 - 07:39 PM
I think you mean Centre of Gravity rather than Roll Centre (which is etermined by the suspension geometry) - but otherwise dead right - that tank needs to be as low as possible and very well baffled to stop the fuel swilling from side to side - vents must go up then down - and should be such that fuel won't escape if the car is upside down............ Of course - some Rally Minis carry spares on the roof - not exactly helpful to the C of G....
Yes, I did mean G of G, sorry about that. I think the tank he has specified will be baffled as it appears to be a comp tank.
The reason those Minis carried the spares on the roof was because on the '66 Monte in order to run in Group 1, which you had to run in to get any chance of a win, a maximum of 8 wheels and tyres only were allowed and these had to all be carried in the competing car. So a roof rack was fitted to carry 2 of the 8 wheels with the other 2 being in the boot. Once the rally proper started, the 4 best tyres were fitted with the other 2, which had been on the back during the concentration run being put in the boot. I was competing in a 'works' NSU on that event, also in Group 1, and we had the same problem. The roof rack was removed at service before the special stages started. I do remember that the roof rack with the tyres really screwed up the performance and increased the fuel consumption alarmingly. Gosh, how long ago that was - happy days!
Posted 29 January 2011 - 07:46 PM
Unfortunately - I see they have just dropped out of the event............
Edited by bmcecosse, 29 January 2011 - 07:54 PM.
Posted 30 January 2011 - 02:27 PM
