Petrol Gauge
6 replies to this topic
#1 edd118118
edd118118
    Just On Tickover
  • 6 posts
Posted 28 January 2011 - 04:20 PM
~~~~~Please delete this text before posting the topic~~~~~~
Please give your topic a title that quickly describes your problem. Just putting 'Help my Mini doesn't work' is useless to anyone trying to help.
Model: austin mini city 998
Year: 1987
my petrol gauge isn't working at all and i have no idea why, it used to work when i put petrol in it would go up to how much i had, but then 5 mins down the road it would say zero again, this was ok to live with, but now it just says zero all the time, what could be the problem n how do i resolve this ?? its becoming annoying broke down twice this week due to no petrol... :thumbsup:
Any non-standard parts that might be involved with the problem?
#2 glyn
glyn
  • 637 posts
  • Local Club: leyland mini club
Posted 28 January 2011 - 04:31 PM
you probably need a new fuel sender (in the tank) fairly easy job just make sure your tank is as empty as you dare!
#3 Leon_mini
Leon_mini
  • 166 posts
connectors on the tank?
connections clean?
#4 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 28 January 2011 - 05:21 PM
Start with the basic tests.
Place the ignition key in the run position.
Open the boot and find the two wires connected to the fuel sending unit. (Black wire = Earth, Green/Black = wire to gauge).
Place a paperclip between the sending unit terminals to "short" the two wires together.
Watch the fuel gauge for a minute or so.
If the gauge went to full, you need a new sending unit. If the gauge did not go to full there are several possibilities. Post back and let us know what you find after the paperclip test.
#5 lapider
lapider
  • 473 posts
  • Local Club: cardiff mini club
Posted 28 January 2011 - 05:44 PM
i would recomend or buying or eaven making a test light with an old indicator unit and a crocodile clip and a live and earth wire. then testing and methodicly tracing the fault.
#6 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 29 January 2011 - 02:40 AM
A test light may prove quite helpful once you know whether the problem is in the sending unit or the wiring. The paperclip test is a first step in determining which part of the system to look at.
#7 edd118118
edd118118
    Just On Tickover
  • 6 posts
Posted 30 January 2011 - 09:39 PM
Year: 1987
my petrol gauge isn't working at all and i have no idea why, it used to work when i put petrol in it would go up to how much i had, but then 5 mins down the road it would say zero again, this was ok to live with, but now it just says zero all the time, what could be the problem n how do i resolve this ?? its becoming annoying broke down twice this week due to no petrol... :o
thanks guys :) narrowed it down to my sender think im just goin to buy a new one... i missed the bingley show does anyone know when the next one is ??
