The Secret Button. . . . . .
21 replies to this topic
#1 johnwoog
johnwoog
  • 20 posts
Posted 28 January 2011 - 05:20 PM
Hey Again guys,
I have a red button on the control panel of my Neon Mini. It's on the far left and the picture on it looks like a brake pedal. As of yet i really have NO CLUE what it does. It's not a click button just a hold on or off one. If any of you could solve this it would be awsome!
Thanks x
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 28 January 2011 - 05:28 PM
:thumbsup: your it this week :P
#3 stickycreambun
stickycreambun
  • 1,865 posts
Posted 28 January 2011 - 05:34 PM
We only playing weekly not daily now?!
:thumbsup:
#4 Jackmorton
Jackmorton
  • 267 posts
  • Local Club: Cumbria mini cruisers
Posted 28 January 2011 - 05:37 PM
It lights up when your brake pads are almost gone if i'm not mistaken. You can just push it to check its working. I might be wrong though.
#5 E.L.M.O
E.L.M.O
  • 3,953 posts
Posted 28 January 2011 - 05:46 PM
I believe it actually measures brake pressure in the system. So brake fluid levels. So If you are leaking fluid, the button will automatically light up. However, sometimes the bulb goes, which is why you can press it to make sure it is working.
Come on guys, dont be mean. Everyone has to learn and its not exactly obvious, even though this question does get asked an awful lot. Perhaps an explanation of what this button does should be pinned, if its not already?
Edited by E.L.M.O, 28 January 2011 - 05:46 PM.
#6 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 28 January 2011 - 05:55 PM
Moved.
#7 johnwoog
johnwoog
  • 20 posts
Posted 28 January 2011 - 05:56 PM
cheers :thumbsup:
#8 Stevee
Stevee
  • 0 posts
  • Local Club: #
Posted 28 January 2011 - 05:57 PM
mine light up when i had no brake fuild in the master cyldinder the button is there just to test the light works
another great British Leyland knowing it was gonna fail so they fixed it :thumbsup:
like eletric wing mirror adjusters also fitted with manuel adjusters just in case!
#9 rick.spi
rick.spi
  • 1,686 posts
  • Local Club: "WOT NO BRAKES"
Posted 28 January 2011 - 06:05 PM
Hey Again guys,
Thanks x
tells you about you brake fluid i think, i think the pressing down bit is just to test if its working. ive never seen mine light up or do anything.
#10 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 28 January 2011 - 06:13 PM
Yup, there is a small float switch in the lid of the brake master cylinder, when the fluid drops below a certain level the switch will illuminate, telling you to sort it out.
Pressing it, simply is a test feature to let you know the bulb is still working.
However, the switch in the lid of the master cylinder usualy corrodes away and won't work, even when it does work, it comes on when the level is waaaaay too low anyway.
#11 charie t
charie t
  • 3,153 posts
Posted 28 January 2011 - 06:25 PM
:thumbsup:
Its there for noobies to gain their 150 post count, isn't it?
Edited by charie t, 28 January 2011 - 06:25 PM.
#12 ibrooks
ibrooks
  • 1,017 posts
Posted 28 January 2011 - 06:54 PM
Given how often the question comes up maybe a sticky would be a good idea?
It has two possible functions that have both been covered (sort of). It is connected to the level switch in the brake fluid cap and should light up if the brake fluid level gets low. On some Minis it is also conected to a switch in the middle of the master cylinder - this is a pressure sensor that switches if the pressure between the two circuits and if it differs by more than a certain amount which implies that there is a leak or burst pipe.
Pushing the button confirms that the bulb is OK (assuming it lights up). Most modern cars have the bulb in parallel with the handbrake warning light so that it is tested when the handbrake is applied.
Iain
#13 SolarB
SolarB
  • 1,385 posts
Posted 28 January 2011 - 07:00 PM
You are mistaken!
:thumbsup: :D :P
#14 Jackmorton
Jackmorton
  • 267 posts
Posted 28 January 2011 - 10:12 PM
You are mistaken!
:thumbsup: :D :P
Pretty sure i said later on. I might be wrong though !
#15 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 28 January 2011 - 10:17 PM
only might be wrong
